IDEX Parts cooling fan turned off
Hi @SiC_FPV
Version 2 - for multiple extruders on one carriages
eg my printer … Test(2) - YouTube
Add to macro Txx
## add to T0 macro
#  CARRIAGE_PRINT_FAN
## add to T1 macro
HW config FANs
# X1 print cooling fan
# [fan_generic fan]
# pin: PC9
# cycle_time: 0.0100
# kick_start_time: 1.00
# X2 print cooling fan
# [fan_generic fan1]
# pin: PA8
# kick_start_time: 1.000
# Other define FANs
# [fan_generic fan2]
# pin:
# [fan_generic fan3]
# pin:
# [fan_generic fan4]
# pin:
# [fan_generic fan5]
# pin:
Macros M160 / M107
# PRINTER FANS MANAGEMENT
# Redefine G-code command M106 and M107
[gcode_macro M106]
description: Override "M106" to allow multiple extruders.
    {% set raw_speed = params.S|default(255)|float %}
    {% set fan_speed = (raw_speed / 255.0)|round(2) %}
    {% if (params.P) is defined %}
      {% set target_fan = params.P|int %}
      {% set default_fan = ('fan', 'fan1', 'fan2', 'fan3', 'fan4', 'fan5')[target_fan] %}
       SET_FAN_SPEED FAN={default_fan} SPEED={fan_speed}
    {% else %}
        ### carriages print cooling FAN
        CARRIAGE_PRINT_FAN SPEED={fan_speed}
    {% endif %}
[gcode_macro M107]
description: Override "M107" to allow multiple extruders.
      M106 S0 P{params.P}
    {% else %}
      M106 S0
    {% endif %}
[gcode_macro CARRIAGE_PRINT_FAN]
description: Set automatically the print fan speed for dual carriages modes
#--- Carriages print cooling FANs ---
variable_fan: 'fan'    # carriage X1
variable_fan1: 'fan1'   # carriage X2
    ### FAN speed
    {% if params.SPEED is defined %}
        {% set fan_speed = params.SPEED|float %}
    {% else %}
        ### read print fan speed from active carriage/extruder
        {% set fan_speed = printer["fan_generic " + fan].speed|float %}
        {% set fan1_speed = printer["fan_generic " + fan1].speed|float %}
        {% set fan_speed = [fan_speed, fan1_speed]|max %}
    {% endif %}
    ### Active FAN for carriage
    {% set active_toolhead =({'extruder':0,'extruder1':1,'extruder2':2,'extruder3':3})[printer['toolhead'].extruder] %}
     {% if active_toolhead in [0,1] %}
        ### FAN on carriage X1
        SET_FAN_SPEED FAN={fan} SPEED={fan_speed}
        SET_FAN_SPEED FAN={fan1} SPEED=0
     {% elif active_toolhead in [2,3] %}
        ### FAN on carriage X2
        SET_FAN_SPEED FAN={fan} SPEED=0
        SET_FAN_SPEED FAN={fan1} SPEED={fan_speed}
    {% endif %}
