The print fan does not turn off when printing on VORON 24r2
Printer Model: VORON v2.4r2 by fysetc
MCU : spider v2.3
klippy (21).log (31.7 KB)
hello everyone. when printing, the fan speed of the model does not turn off when it is turned off in the slicer, adding cycle_time allows you to slow down the speed, but not turn it off completely. I have seen printer cfg options of other users and there are a minimum of parameters in the print cooling fan section and they are apparently satisfied with everything.
can you tell me what needs to be changed in the configuration file so that the fan turns off completely? maybe something else needs to be changed somewhere? fan- came complete with a printer 24v 0.01 (sort of)
# This file contains common pin mappings for the Fysetc Spider board.
# To use this config, the firmware should be compiled for the STM32F446.
# When calling "menuconfig", enable "extra low-level configuration setup"
# and select the "12MHz crystal" as clock reference
# For flashing, write the compiled klipper.bin to memory location 0x08000000
## Voron Design VORON2 250/300/350mm Spider TMC2209 UART config
## *** THINGS TO CHANGE/CHECK: ***
## Spider version                       Please search this file for "SpiderVersion" and uncomment the appropriate line for each
## MCU paths                            [mcu] section
## Thermistor types                     [extruder] and [heater_bed] sections - See 'sensor types' list at end of file
## Z Endstop Switch location            [safe_z_home] section
## Homing end position                  [gcode_macro G32] section
## Z Endstop Switch  offset for Z0      [stepper_z] section
## Probe points                         [quad_gantry_level] section
## Min & Max gantry corner postions     [quad_gantry_level] section
## PID tune                             [extruder] and [heater_bed] sections
## Fine tune E steps                    [extruder] section
#[include PIS.cfg]
## Uncomment below if you're using the Raspberry uart0 to communicate with Spider
#restart_method: command
##  You need to select 'Communication interface' to USB in 'make menuconfig'
##  when you compile Klipper for Spider
##	Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_40003C000551303439343636-if00
##	If you want to use the Raspberry uart0 to communicate with Spider,
##  you need to select 'Communication interface' to 'Serial (on USART1 PA10/PA9)'
##  in 'make menuconfig' when you compile klipper and set the serial as below
#serial: /dev/ttyAMA0
[printer]
kinematics: corexy
max_velocity: 300
#max_accel: 3000			        #Max 4000
max_accel: 2000
max_z_velocity: 15			#Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 300
square_corner_velocity: 5.0
#      X/Y Stepper Settings
[stepper_x]
##	Connected to X-MOT (B Motor)
step_pin: PE11
dir_pin: PE10
enable_pin: !PE9
rotation_distance: 40
microsteps: 32
#microsteps: 32
full_steps_per_rotation: 200  #set to 400 for 0.9 degree stepper
#full_steps_per_rotation: 400  #set to 400 for 0.9 degree stepper
endstop_pin: ^PB14
position_min: 0
##	Uncomment below for 250mm build
#position_endstop: 250
#position_max: 250
##	Uncomment for 300mm build
#position_endstop: 300
#position_max: 300
##	Uncomment for 350mm build
position_endstop: 350
position_max: 350
homing_speed: 30   #Max 100
homing_retract_dist: 5
homing_positive_dir: true
##	Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PE7
interpolate: true
#run_current: 0.7
run_current: 1.1
hold_current: 0.4
sense_resistor: 0.110
stealthchop_threshold: 0
#stealthchop_threshold: 999999
##  Make sure to update below for your relevant driver (5160)
#[tmc5160 stepper_x]
## Soft SPI
#spi_software_mosi_pin: PE14
#spi_software_miso_pin: PE13
#spi_software_sclk_pin: PE12
#cs_pin: PE7
#interpolate: True
#diag1_pin: PB14
#run_current: 0.800
#hold_current: 0.500
##stealthchop_threshold: 0
[stepper_y]
##	Connected to Y-MOT (A Motor)
step_pin: PD8
dir_pin: PB12
enable_pin: !PD9
#microsteps: 32
microsteps: 32
endstop_pin: ^PB13
position_min: 0
##	Uncomment for 250mm build
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PE15
interpolate: true
#run_current: 0.7
run_current: 1.1
hold_current: 0.4
#tealthchop_threshold: 999999
#[tmc5160 stepper_y]
## Soft SPI
#cs_pin: PE15
##diag1_pin: PB13
#interpolate: True
#run_current: 0.8
#hold_current: 0.7
#   Z Stepper Settings
## In Z-MOT Position
## Z0 Stepper - Front Left
step_pin: PD14
dir_pin: PD13
enable_pin: !PD15
gear_ratio: 80:16
microsteps: 32
##  In Z- Position
endstop_pin: ^PA0
##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
##  (+) value = endstop above Z0, (-) value = endstop below
##	Increasing position_endstop brings nozzle closer to the bed
##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
#position_endstop: -0.5
#position_max: 240
##	Uncomment below for 300mm build
#position_max: 290
##	Uncomment below for 350mm build
position_max: 340
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PD10
interpolate: true
run_current: 0.7
hold_current: 0.4
##	In E1-MOT Position
##	Z1 Stepper - Rear Left
[stepper_z1]
step_pin: PE6
dir_pin: !PC13
enable_pin: !PE5
gear_ratio: 80:16
[tmc2209 stepper_z1]
uart_pin: PC14
interpolate: true
run_current: 0.7
hold_current: 0.4
##	In E2-MOT Position
##	Z2 Stepper - Rear Right
[stepper_z2]
step_pin: PE2
dir_pin: PE4
enable_pin: !PE3
gear_ratio: 80:16
[tmc2209 stepper_z2]
uart_pin: PC15
interpolate: true
run_current: 0.7
hold_current: 0.4
##	In E3-MOT Position
##	Z3 Stepper - Front Right
[stepper_z3]
step_pin: PD12
dir_pin: !PC4
enable_pin: !PE8
gear_ratio: 80:16
[tmc2209 stepper_z3]
uart_pin: PA15
interpolate: true
run_current: 0.7
hold_current: 0.4
#   Extruder
##	In E0-MOT Position
step_pin: PD5
dir_pin: PD6
enable_pin: !PD4
##	Update value below when you perform extruder calibration
##	If you ask for 100mm of filament, but in reality it is 98mm:
##	rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
##  22.6789511 is a good starting point
#rotation_distance: 22.6789511	#Bondtech 5mm Drive Gears
#rotation_distance: 21.318214034
#rotation_distance: 21.10503189366
#rotation_distance: 20.4718809368502
#rotation_distance: 21.290756174324208
#rotation_distance: 20.6520334
rotation_distance: 21.68463507
##	Update Gear Ratio depending on your Extruder Type
##	Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
##	Use 80:20 for M4, M3.1
gear_ratio: 50:17				#BMG Gear Ratio
full_steps_per_rotation: 200	#200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.75
##      In E0 OUT Position
heater_pin: PB15
##	Validate the following thermistor type to make sure it is correct
sensor_type: ATC Semitec 104GT-2 #Generic 3950
sensor_pin: PC0 # TE0 Position
min_temp: 10
max_temp: 270
max_power: 1.0
min_extrude_temp: 170
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##	Try to keep pressure_advance below 1.0
pressure_advance: 0.05
##	Default is 0.040, leave stock
pressure_advance_smooth_time: 0.040
[tmc2209 extruder]
uart_pin: PD7
interpolate: false
run_current: 0.5
hold_current: 0.2
#   Bed Heater
[heater_bed]
##	SSR Pin - In BED OUT position
heater_pin: PB4
sensor_type: NTC 100K MGB18-104F39050L32 # Generic 3950
##  Uncomment below for SpiderVersion 1.x
#sensor_pin: PC3 # TB Position
##  Uncomment below for SpiderVersion 2.2
sensor_pin: PB0 # TB Position
##	Adjust Max Power so your heater doesn't warp your bed
max_power: 0.6
min_temp: 0
max_temp: 110
#control: pid
#pid_kp: 58.437
#pid_ki: 2.347
#pid_kd: 363.769
#	Probe
[probe]
##	Inductive Probe - If you use this section , please comment the [bltouch] section
##	This probe is not used for Z height, only Quad Gantry Leveling
##	In Z+ position
##	If your probe is NC instead of NO, add change pin to ^PA3
pin: ^PA3
x_offset: 0
y_offset: 25.0
#z_offset: 0
z_offset: -0.5
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 2
#samples_tolerance: 0.006
samples_tolerance: 0.004
samples_tolerance_retries: 3
#	Bltouch
#[bltouch]
##	Bltouch - If you use this section , please comment the [probe] section
##	More infomation at : https://www.klipper3d.org/BLTouch.html
##	This bltouch is not used for Z height, only Quad Gantry Leveling
##	In Z+ Position
#sensor_pin: PA0
##	In Y+ Position
#control_pin: PA2
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
#samples_result: median
#sample_retract_dist: 3.0
#samples_tolerance_retries: 3
#	Fan Control
[heater_fan hotend_fan]
##	Hotend Fan - FAN0 Connector
#pin: PB0
pin: PA13
max_power: 1.0
kick_start_time: 0.5
heater: extruder
heater_temp: 50.0
##	If you are experiencing back flow, you can reduce fan_speed
fan_speed: 1.0
[fan]
##	Print Cooling Fan - FAN1 Connector
#pin: PB1
pin: PA14
max_power: 0.7
cycle_time: 0.025
##	Depending on your fan, you may need to increase this value
##	if your fan will not start. Can change cycle_time (increase)
##	if your fan is not able to slow down effectively
off_below: 0.10
[heater_fan controller_fan]
##	Controller fan - FAN2 Connector
pin: PB2
#kick_start_time: 0.5
kick_start_time: 0.7
heater: heater_bed
heater_temp: 45.0
#[heater_fan exhaust_fan]
##  Exhaust fan - In E2 OUT Positon
#pin: PB3
#max_power: 0.4
#shutdown_speed: 0.0
#kick_start_time: 5.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
#[controller_fan nevermore]
# Nevermore - In E1 OUT Position
#pin: PC8
#kick_start_time: 0.500
#fan_speed: 0.5
#	LED Control
#[output_pin caselight ]
##  Chamber Lighting - In 5V-RGB Position
#pin: PD3
#pwm: true
#shutdown_value: 0
#value:100
#cycle_time: 0.01
#	Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
##	XY Location of the Z Endstop Switch
##	Update -100,-100 to the XY coordinates of your endstop pin
##	(such as 157,305) after going through Z Endstop Pin
##	Location Definition step.
home_xy_position:231,350
speed:100
z_hop:10
[quad_gantry_level]
##	Use QUAD_GANTRY_LEVEL to level a gantry.
##	Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##	MAX (250, 250), (300,300), or (350,350) depending on your printer size
##	to respective belt positions
##	Gantry Corners for 250mm Build
#gantry_corners:
#	-60,-10
#	310, 320
##	Probe points
#points:
#	50,25
#	50,175
#	200,175
#	200,25
##	Gantry Corners for 300mm Build
#gantry_corners:
#	-60,-10
#	360,370
##	Probe points
	50,25
	50,225
	250,225
	250,25
##	Gantry Corners for 350mm Build
gantry_corners:
	-60,-10
	410,420
##	Probe points
	50,25
	50,275
	300,275
	300,25
speed: 100
horizontal_move_z: 10
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
#	Displays
[display]
#	mini12864 LCD Display
lcd_type: uc1701
cs_pin: PC11
a0_pin: PD2
rst_pin: PC10
encoder_pins: ^PC6,^PC7
click_pin: ^!PA8
contrast: 63
#spi_bus: spi1
spi_software_mosi_pin: PA7
spi_software_miso_pin: PA6
spi_software_sclk_pin: PA5
[neopixel fysetc_mini12864]
#	To control Neopixel RGB in mini12864 display
pin: PC12
chain_count: 3
initial_RED: 0.1
initial_GREEN: 0.5
initial_BLUE: 0.0
color_order: RGB
#	Set RGB values on boot up for each Neopixel.
#	Index 1 = display, Index 2 and 3 = Knob
[delayed_gcode setdisplayneopixel]
initial_duration: 1
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=1 BLUE=1 INDEX=1 TRANSMIT=0
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
[bed_mesh]
speed: 100
#mesh_min: 40, 40
#mesh_max: 210,210
#mesh_min: 40, 40
#mesh_max: 260,260
mesh_min: 40, 40
mesh_max: 310,310
fade_start: 0.6
fade_end: 10.0
probe_count: 5,5 # Values should be odd, so one point is directly at bed center
algorithm: bicubic
relative_reference_index: 12 # Update when changing probe_count, to ((x points * y points) - 1) / 2. (the center point)
##температурные сенсоры
[temperature_sensor raspberry_pi]
## Pi Temps
sensor_type: temperature_host
max_temp: 100
[temperature_sensor mcu_temp]
## Spider Temps
sensor_type: temperature_mcu
max_temp: 100
#	Macros
[gcode_macro G32]
    BED_MESH_CLEAR
    G28
    QUAD_GANTRY_LEVEL
    G28
    ##	Uncomment for for your size printer:
    #G0 X125 Y125 Z30 F3600
    ##	Uncomment for 300 build
    #G0 X150 Y150 Z30 F3600
    G0 X175 Y175 Z30 F3600
#[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
#original config-remove if mod doesnt work
#gcode:
    #G32                            ; home all axes
    #G1 Z20 F3000                   ; move nozzle away from bed
    G32                            ; home all axes
    BED_MESH_PROFILE LOAD=bad_platform
    #BED_MESH_CALIBRATE
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-1.0 F3600                 ; retract filament
    G91                            ; relative positioning
    G0 Z1.00 X20.0 Y20.0 F20000    ; move nozzle to remove stringing
    TURN_OFF_HEATERS
    M107                           ; turn off fan
    G1 Z2 F3000                    ; move nozzle up 2mm
    G90                            ; absolute positioning
    G0  X125 Y250 F3600            ; park nozzle at rear
    BED_MESH_CLEAR
[virtual_sdcard]
path: ~/printer_data/gcodes
[pause_resume]
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
  TURN_OFF_HEATERS
  CANCEL_PRINT_BASE
## 	Thermistor Types
##   "EPCOS 100K B57560G104F"
##   "ATC Semitec 104GT-2"
##   "NTC 100K beta 3950"
##   "Honeywell 100K 135-104LAG-J01"
##   "NTC 100K MGB18-104F39050L32" (Keenovo Heater Pad)
##   "AD595"
##   "PT100 INA826"
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 39.493
#*# pid_ki = 1.755
#*# pid_kd = 222.150
#*# [extruder]
#*# control = pid
#*# pid_kp = 20.088
#*# pid_ki = 0.950
#*# pid_kd = 106.216
#*# [stepper_z]
#*# position_endstop = -0.154
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	0.151250, 0.038750, -0.038750, -0.083750, -0.097500
#*# 	0.047500, 0.013750, -0.027500, -0.070000, 0.126250
#*# 	0.036250, 0.010000, 0.000000, -0.056250, -0.146250
#*# 	0.067500, 0.058750, 0.061250, 0.015000, -0.031250
#*# 	0.141250, 0.168750, 0.205000, 0.223750, 0.158750
#*# tension = 0.2
#*# min_x = 40.0
#*# algo = bicubic
#*# y_count = 5
#*# mesh_y_pps = 2
#*# min_y = 40.0
#*# x_count = 5
#*# max_y = 310.0
#*# mesh_x_pps = 2
#*# max_x = 310.0
#*# [probe]
#*# z_offset = 2.100
#*# [bed_mesh default  2]
#*# version = 1
#*# points =
#*# 	0.062500, 0.062500, 0.065000, 0.085000, 0.023750
#*# 	-0.048750, -0.025000, 0.028750, 0.025000, -0.068750
#*# 	-0.077500, -0.053750, 0.000000, -0.007500, -0.086250
#*# 	-0.047500, -0.026250, -0.002500, -0.027500, -0.062500
#*# 	0.071250, 0.093750, 0.108750, 0.125000, 0.048750
#*# tension = 0.2
#*# min_x = 40.0
#*# algo = bicubic
#*# y_count = 5
#*# mesh_y_pps = 2
#*# min_y = 40.0
#*# x_count = 5
#*# max_y = 310.0
#*# mesh_x_pps = 2
#*# max_x = 310.0
#*# [bed_mesh bad_platform]
#*# version = 1
#*# points =
#*# tension = 0.2
#*# min_x = 40.0
#*# algo = bicubic
#*# y_count = 5
#*# mesh_y_pps = 2
#*# min_y = 40.0
#*# x_count = 5
#*# max_y = 310.0
#*# mesh_x_pps = 2
#*# max_x = 310.0
The heatsink / heater fan or the part cooling fan?
If part cooling fan then it is controlled via gcode. Add a fan off statement in your end gcode of the slicer or end_print macro, e.g. M107
i mean print cooling fan.
or maybe you can give an example of an endcode?
in the code attached to the post there is macro print_end and there is m107. Or is it not about that?
the problem is that the sliders can’t control the fan speed when printing abs.
if I move the slider in fluid, it feels like the fan changes speed, but still not the way I need
my inattention. jumpers were installed on 12v. rearranged to 24, now everything is ok
