Internal error during connect
Printer Model: Custom
MCU / Printerboard: BIGTREETECH Manta M8P
After update via update manager it throws this error :
Internal error during connect: init() takes 2 positional arguments but 3 were given
In the attachment I send klippy.log and also klippy.py where the error is supposedly. But I can’t fix it.
Could anyone help me ? I also tried a clean install of klipper but it didn’t help. I think there is some problem with dockable_probe.py.
klippy.log (37.2 KB)
klippy.zip (4.2 KB)
  File "/home/biqu/klipper/klippy/extras/dockable_probe.py", line 600, in load_config
    config.get_printer().add_object('probe', probe.PrinterProbe(config, msp))
TypeError: __init__() takes 2 positional arguments but 3 were given
That dockable_probe.py isn’t stock Klipper, so you should consult the supplier of that file as to why it’s not working
It doesn’t look to be from the base Klipper repo.
It is from nielsvz/klipper_dockable_probe (github.com)
I wasn’t quite sure if there was a problem.
Project is archived so i need to change the way to probe.
Thank you for your help
