- Printer Model: Custom
- MCU / Printerboard: BTT M8P V2.0
- Host / SBC: CB1
- Printhead: EBB36 CAN V1.1,
- klippy.log:
logs.zip (6.2 MB)
also use BTT MMB - Klipper version: v0.12.0-378
Issue:
During an SD card print of a large model (400x400x400 mm build area), the printer encountered a loss of communication with the MCU, causing the print to stop. The error was triggered by internal failures in processing the G1 command, specifically related to the stepcompress module on the microcontroller. Despite multiple troubleshooting attempts, the issue persists in occurs in random time.
Voltage stability has been thoroughly checked, and no irregularities were found.
The issue persists even after increasing the CAN bus buffer size.
Main errors that i found:
Lost communication with MCU 'MMB'.mcu.error: Internal error in MCU 'mcu' stepcompress.- Failure during
G1command processing
