Printer Model: Anycubic Mega S
MCU / Printerboard: Trigorilla 0.0.2
Host / SBC: Octoprint 1.10.2 / Raspberyy PI 4 / OctoPI 1.0.0
logs.txt (120.5 KB)
Using FIRMWARE_RESTART command after establishment of a connection to /tmp/printer from Octoprint. I am doing it like this to reset the printer to have it running after reconnection after a M112 shutdown.
This run into an Internal error on command:“FIRMWARE_RESTART” on the “second” connection attempt. The first one is fine and if I disconnect manually without a M112 the second connection to /tmp/printer runs into this error.
This is annoying as I have to restart Klipper and connect to it manually every time.
As I am using Klipper since 3 days and are still in the setup phase please correct me if this is the wrong place for reporting bugs.
Nils
