bihai
1
Printer Model: stm32f103c6t6
MCU / Printerboard:
restart_method: command
1# restart_method:arduino
baud: 250000
my issue just like this frequently asked question
When I set restart_method=command my AVR device just hangs on a restart
No matter what the reason is , if the communication between CPU and MCU is lost,
it would not be possible to reconnect with the MCU by clicking on restart firmware or restart klipper or moonrake.
The only way to establish connection is to power the klipper driver board again.
Besides, I do not use bootloader. I flashed the compiled bin into the mcu by stlink .
Linux host PC communicates with STM32F103C6 board via CH340.
can anyone help me !!!
Hello @bihai !
Maybe restarting the Klipper service from the CLI can do it:
echo FIRMWARE_RESTART > /tmp/printer
Normally if you have Klipper firmware on the device communicating via USB the ID will start with
usb-klipper
bihai
4
what do you mean i do not undstand ,and what should i do
Do you have the Klipper firmware on your board?
bihai
6
yes,
I have already used klipper to print several times. but i did not use any bootloader
Once connection is lost, The only solution.is to unplug and reconnect the USB cable.
bihai
8
issue solved restart method cheath
