Failed automated reset of MCU 'mcu'
Printer Model: JG Maker Artist-D IDEX
MCU / Printerboard: MKS Robin Pro
klippy.log (873.0 KB)
Printer Config:
printer (1).cfg (8.9 KB)
The printer motherboard does not reset / reboot when firmware restart is called, and it gives an error until I reset the printer manually.
I added GPIO startup pin as !PA14 on the J-Tag as I understood it should be, but it did not work like other reported for the MKS Robin E3.
Thanks,
/retnel
I found the answer here finally.
Just add restart_method: command to [mcu}
/retnel
