I’ve had Klipper/Fluidd running for about a month with no major hiccups until now.
The printer got power cycled (which has happened before without issue) and now
mcu ‘mcu’: Unable to connect
Error configuring printer
klippy.log (69.3 KB)
Line 244 has
ls: cannot access ‘/dev/serial/by-id/*’: No such file or directory
Tried lsusb
Bus 001 Device 005: ID 046d:0843 Logitech, Inc. Webcam C930e
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Not really sure where to go from here…
I decided to try and reflash, but am stuck again. Can’t connect still so I can’t flash from the pi. Since it’s a “common” board atmega2560, there is no bin file being created that I can copy to an sd card.
