Problem with mcu connection after update
Printer Model: Custom
MCU / Printerboard: BTT Manta M8p V2
klippy (22).log (435.3 KB)
After i update and flash the firmware i got this error : mcu ‘CB1’: Unable to connect
Error configuring printer
My process to flash the firmware:
  • sudo service klipper stop
  • make menuconfig
  • make clean
  • make
  • click boot0 and reset (already confirm if already set to DFU)
  • make flash FLASH_DEVICE=0483:df11
  • sudo reboot
Also idk why but i can’t flash the firmware using sd card (already confirm the correct slot “soc” and correct name “firmware.bin”)
Additional info:
Thanks for your help beforehand
found the solution with help from discord, i shouldn’t add [mcu] serial: … to the printer.cfg
