Issue with PID_CALIBRATE / heater_generic / SAVE_CONFIG
[Elegoo Neptune 4 Pro] Printer Model:
[STM32F401 ZNP-K1 V1.0] MCU / Printerboard:
After tuning the PID settings for a generic heater [heater_generic heater_bed_outer], saving the configuration incorrectly updates the printer.cfg.
The SAVE_CONFIG section should label the heater as its full name;
#*# [heater_generic heater_bed_outer]
Currently, it just writes #*# [heater_bed_outer], causing the system to ignore the new PID settings. This also causes the previous PID values further up the printer.cfg to be left un-commented out.
Manual Fix: Rename the section from ## [heater_bed_outer] to # # [heater_generic heater_bed_outer] and manually comment out the old PID values further up the printer.cfg to ensure the new settings are used.
printer.cfg after running PID_CALIBRATE HEATER=heater_bed_outer TARGET=60
heater_pin:PC8
max_power:1.0
sensor_type: NTC 100K MGB18-104F39050L32
sensor_pin:PC2
control = pid
pid_kp = 75.301
pid_ki = 1.383
pid_kd = 1025.032
min_temp:0
max_temp:120
pwm_cycle_time: 0.0167
## <---------------------- SAVE_CONFIG ---------------------->
# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
## control = pid
# pid_kp = 73.372
## pid_ki = 0.807
# pid_kd = 1667.369
Hello @halfmanbear !
Where is the klippy.log that has been asked for?
Please attach it to your next post.
Indeed, I can replicate this behavior. Seems a bug.
yes I think it’s this in pid_calibrate.py
heater_name = gcmd.get(‘HEATER’)
Think needs a condition if it’s a generic heater so ‘heater_generic’ can be prepended
I’ve created Fix PID_CALIBRATE command when used with heater_generic by KevinOConnor · Pull Request #6517 · Klipper3d/klipper · GitHub as a fix for this issue.
