Printer Model: Voron 2.4
MCU / Printerboard: Fysetc Spider
klippy.log (5.1 MB)
Alright so I just tore down my V2.4 with around 5000 hours on it and did the R2 upgrade, as well as CANBus. In terms of firmware, I just ran the original instance of Klipper and Mainsail that I installed originally and upgraded all packages etc. through the web UI.
Like an idiot, I deleted alot of stuff from the very bottom of the printer.cfg file thinking I wouldn’t need it i.e. where it says ‘DO NOT EDIT THIS BLOCK OR BELOW’ such as bed meshes, skew correction values, etc. I also deleted my hotend PID tuning info from here, and now I’m having issues when I try to SAVE_CONFIG after PID autotuning. The heatbed is fine, because I guess I didn’t delete this, but once I PID autotune the hotend and try to save I get the following error:
SAVE_CONFIG section ‘extruder’ option ‘control’ conflicts with included value
Have I broken the SAVE_CONFIG function for my hotend PID autotuning, as well as all the other stuff that was there that got deleted i.e. aforementioned skew correction. bed mesh, etc? Do I need to reinstall Klipper? No matter how much I try to manually uncomment out the PID values in my extruder section I can’t get the new values to autosave.
For now, I’ve just been pasting the values back in manually, but that’s kinda annoying long-term.
TIA, klippy log is attached.
