Hello,
I built a belted Voron Trident, the issue I have is that the z axis can sag when power is of.
Currently for probing I use TAP ==> when the z axis drops it will run into problem during z-tilt I occassionaly run into problems as that I reach the end of the linear rail before I sucessfully probe.
My solution for this would be:
One endstop for each of my z-axis at max, to roughly level the build plate and after this using the probe to perform a homing/adjusting z offset and performing tilt.
Would this be possible?
I have seen in the documentation that I can define an endstop for z, z1 and z2 but how is the probing/offset handled?
Thank you!
Lukas
