Okay, so after this change, printer boots, but it still crashes during QGL with Lost communication with MCU 'can0'
For clarity:
My /etc/network/interfaces.d/can0 is:
auto can0
iface can0 can static
bitrate 1000000
up ifconfig $IFACE txqueuelen 128
My printer.cfg is:
printer.cfg (9.1 KB)
(I included the minimum amount of Klicky configs/macro files to make it possible to perform QGL)
sudo dmesg reports:
pi@V24RP:~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.103-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:21:37 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] DMA zone: 2016 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 229376 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=b1d487b5-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 826024K/917504K available (10240K kernel code, 1312K rwdata, 2952K rodata, 1024K init, 862K bss, 25944K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32081 entries in 95 pages
[ 0.000000] ftrace: allocated 94 pages with 5 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000310] Console: colour dummy device 80x30
[ 0.001131] printk: console [tty1] enabled
[ 0.001204] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001263] pid_max: default: 32768 minimum: 301
[ 0.001489] LSM: Security Framework initializing
[ 0.001753] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001802] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003274] cgroup: Disabling memory control group subsystem
[ 0.003559] CPU: Testing write buffer coherency: ok
[ 0.004076] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005334] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005543] rcu: Hierarchical SRCU implementation.
[ 0.006481] smp: Bringing up secondary CPUs ...
[ 0.007653] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008929] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010244] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010402] smp: Brought up 1 node, 4 CPUs
[ 0.010456] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010488] CPU: All CPU(s) started in HYP mode.
[ 0.010515] CPU: Virtualization extensions available.
[ 0.011520] devtmpfs: initialized
[ 0.029036] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.029332] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029394] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.032438] pinctrl core: initialized pinctrl subsystem
[ 0.033640] NET: Registered protocol family 16
[ 0.037856] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.043600] audit: initializing netlink subsys (disabled)
[ 0.044514] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045310] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.045537] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.045579] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.045901] Serial: AMBA PL011 UART driver
[ 0.065276] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080151] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:08:00, variant start_x
[ 0.090163] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.134405] Kprobes globally optimized
[ 0.139425] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141802] SCSI subsystem initialized
[ 0.142088] usbcore: registered new interface driver usbfs
[ 0.142174] usbcore: registered new interface driver hub
[ 0.142267] usbcore: registered new device driver usb
[ 0.144203] clocksource: Switched to clocksource arch_sys_counter
[ 1.863374] VFS: Disk quotas dquot_6.6.0
[ 1.863527] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.863751] FS-Cache: Loaded
[ 1.864006] CacheFiles: Loaded
[ 1.873968] NET: Registered protocol family 2
[ 1.874317] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.876414] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.876509] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.876654] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.876867] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.877072] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.877151] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.877456] NET: Registered protocol family 1
[ 1.878306] RPC: Registered named UNIX socket transport module.
[ 1.878341] RPC: Registered udp transport module.
[ 1.878370] RPC: Registered tcp transport module.
[ 1.878399] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.880069] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.883792] Initialise system trusted keyrings
[ 1.884080] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.893697] zbud: loaded
[ 1.895846] FS-Cache: Netfs 'nfs' registered for caching
[ 1.896765] NFS: Registering the id_resolver key type
[ 1.896827] Key type id_resolver registered
[ 1.896857] Key type id_legacy registered
[ 1.897028] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.897065] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.898297] Key type asymmetric registered
[ 1.898331] Asymmetric key parser 'x509' registered
[ 1.898403] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.898443] io scheduler mq-deadline registered
[ 1.898473] io scheduler kyber registered
[ 1.902011] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.914701] Console: switching to colour frame buffer device 82x26
[ 1.922021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.931116] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.936046] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.939042] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.945056] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.962602] brd: module loaded
[ 1.977575] loop: module loaded
[ 1.982145] Loading iSCSI transport class v2.0-870.
[ 1.986802] usbcore: registered new interface driver lan78xx
[ 1.989525] usbcore: registered new interface driver smsc95xx
[ 1.992124] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.723189] Core Release: 2.80a
[ 2.725758] Setting default values for core params
[ 2.728272] Finished setting default values for core params
[ 2.931149] Using Buffer DMA mode
[ 2.933673] Periodic Transfer Interrupt Enhancement - disabled
[ 2.936287] Multiprocessor Interrupt Enhancement - disabled
[ 2.938874] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.941416] Dedicated Tx FIFOs mode
[ 2.944431] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
[ 2.951524] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.962491] dwc_otg: Microframe scheduler enabled
[ 2.962572] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.966892] WARN::hcd_init_fiq:458: FIQ ASM at 807cb8b8 length 36
[ 2.971322] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 2.975773] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.978085] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.980453] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.982774] Init: Port Power? op_state=1
[ 2.985020] Init: Power Port (0)
[ 2.987542] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.992130] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.994611] usb usb1: Product: DWC OTG Controller
[ 2.996969] usb usb1: Manufacturer: Linux 5.10.103-v7+ dwc_otg_hcd
[ 2.999364] usb usb1: SerialNumber: 3f980000.usb
[ 3.002543] hub 1-0:1.0: USB hub found
[ 3.005026] hub 1-0:1.0: 1 port detected
[ 3.008849] dwc_otg: FIQ enabled
[ 3.008862] dwc_otg: NAK holdoff enabled
[ 3.008874] dwc_otg: FIQ split-transaction FSM enabled
[ 3.008892] Module dwc_common_port init
[ 3.009183] usbcore: registered new interface driver usb-storage
[ 3.011851] mousedev: PS/2 mouse device common for all mice
[ 3.015549] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.020736] sdhci: Secure Digital Host Controller Interface driver
[ 3.023275] sdhci: Copyright(c) Pierre Ossman
[ 3.026573] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.029819] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.032639] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.037180] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.040203] hid: raw HID events driver (C) Jiri Kosina
[ 3.042958] usbcore: registered new interface driver usbhid
[ 3.045600] usbhid: USB HID core driver
[ 3.053493] Initializing XFRM netlink socket
[ 3.056149] NET: Registered protocol family 17
[ 3.058767] Key type dns_resolver registered
[ 3.061732] Registering SWP/SWPB emulation handler
[ 3.064266] registered taskstats version 1
[ 3.066613] Loading compiled-in X.509 certificates
[ 3.069822] Key type ._fscrypt registered
[ 3.072147] Key type .fscrypt registered
[ 3.074505] Key type fscrypt-provisioning registered
[ 3.088018] uart-pl011 3f201000.serial: there is not valid maps for state default
[ 3.092879] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.095420] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.102649] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.106958] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.109484] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.134353] Indeed it is in host mode hprt0 = 00021501
[ 3.198677] sdhost: log_buf @ (ptrval) (f4113000)
[ 3.239557] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.243678] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.247762] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.251130] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.256441] of_cfs_init
[ 3.259010] of_cfs_init: OK
[ 3.262501] Waiting for root device PARTUUID=b1d487b5-02...
[ 3.275535] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.342603] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.347499] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.350239] Indeed it is in host mode hprt0 = 00001101
[ 3.414448] mmc0: new high speed SDHC card at address aaaa
[ 3.417931] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 3.423519] mmc1: new high speed SDIO card at address 0001
[ 3.428482] mmcblk0: p1 p2
[ 3.454310] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.456659] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.584653] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.589370] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.592729] hub 1-1:1.0: USB hub found
[ 3.595432] hub 1-1:1.0: 4 ports detected
[ 3.648351] EXT4-fs (mmcblk0p2): recovery complete
[ 3.653103] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.658477] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.669267] devtmpfs: mounted
[ 3.679548] Freeing unused kernel memory: 1024K
[ 3.682763] Run /sbin/init as init process
[ 3.685421] with arguments:
[ 3.685432] /sbin/init
[ 3.685443] with environment:
[ 3.685454] HOME=/
[ 3.685465] TERM=linux
[ 3.914269] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.044637] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 4.049986] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.053725] hub 1-1.1:1.0: USB hub found
[ 4.056689] hub 1-1.1:1.0: 3 ports detected
[ 4.154271] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 4.261393] systemd[1]: System time before build time, advancing clock.
[ 4.301277] usb 1-1.2: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
[ 4.306772] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.309591] usb 1-1.2: Product: stm32f446xx
[ 4.312323] usb 1-1.2: Manufacturer: Klipper
[ 4.315084] usb 1-1.2: SerialNumber: 400043000451303431333234
[ 4.420807] NET: Registered protocol family 10
[ 4.425104] Segment Routing with IPv6
[ 4.505866] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.515448] systemd[1]: Detected architecture arm.
[ 4.593923] systemd[1]: Set hostname to <V24RP>.
[ 4.624330] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 4.758316] usb 1-1.3: New USB device found, idVendor=1d50, idProduct=606f, bcdDevice= 0.00
[ 4.764271] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.767263] usb 1-1.3: Product: CANable-MKS gs_usb
[ 4.770436] usb 1-1.3: Manufacturer: makerbase
[ 4.773154] usb 1-1.3: SerialNumber: 001C00355741570D20393033
[ 5.054284] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
[ 5.184863] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 5.190352] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.470818] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.499824] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.552735] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.569920] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.574405] systemd[1]: Listening on Journal Socket.
[ 5.581156] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.592343] systemd[1]: Starting Restore / save the current clock...
[ 5.600212] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.611215] systemd[1]: Listening on Syslog Socket.
[ 5.618867] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.630231] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.641080] systemd[1]: Listening on udev Kernel Socket.
[ 5.864043] mc: Linux media interface: v0.10
[ 5.907659] videodev: Linux video capture interface: v2.00
[ 5.959066] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.966234] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.968743] [vc_sm_connected_init]: start
[ 5.972080] [vc_sm_connected_init]: installed successfully
[ 6.000203] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.047573] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.367928] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.521192] systemd-journald[120]: Received request to flush runtime journal from PID 1
[ 7.173891] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.181790] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.182279] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.182679] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.183138] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.183167] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.183209] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.183231] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.183252] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.183470] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.203627] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.241543] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.241628] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.247905] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.247964] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.256263] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.256320] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.259702] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.259757] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.261831] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.270875] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.631116] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.636921] CAN device driver interface
[ 7.642777] gs_usb 1-1.3:1.0: Configuring for 1 interfaces
[ 7.644460] usbcore: registered new interface driver gs_usb
[ 7.743364] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
[ 7.745029] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.745797] usbcore: registered new interface driver cdc_acm
[ 7.745816] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 7.784772] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.849990] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.877801] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.884787] usbcore: registered new interface driver brcmfmac
[ 8.173404] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.210731] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 8.775615] random: crng init done
[ 8.775642] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.468919] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 10.148728] 8021q: 802.1Q VLAN Support v1.8
[ 10.314241] Adding 262140k swap on /var/swap. Priority:-2 extents:2 across:286716k SSFS
[ 10.332944] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.521145] 8021q: adding VLAN 0 to HW filter on device eth0
[ 15.875783] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.760770] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 30.031546] can: controller area network core
[ 30.031627] NET: Registered protocol family 29
[ 30.043749] can: raw protocol
[ 111.595151] usb 1-1.2: USB disconnect, device number 4
[ 113.165586] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
[ 113.312610] usb 1-1.2: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
[ 113.312623] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 113.312630] usb 1-1.2: Product: stm32f446xx
[ 113.312637] usb 1-1.2: Manufacturer: Klipper
[ 113.312643] usb 1-1.2: SerialNumber: 400043000451303431333234
[ 113.314773] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
ifconfig reports:
pi@V24RP:~ $ ifconfig
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 128 (UNSPEC)
RX packets 1282863 bytes 10257756 (9.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1749 bytes 10162 (9.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Klippy.log right after crash:
klippy(20).log (457.6 KB)
