Issues with [sdcard_loop]
Printer Model: DIY Filament Spooler
MCU / Printerboard: Megatronics V3
Host / SBC: RaspberryPi 3
klippy.log (41.1 KB)
I try to establish the loop function with [sdcard_loop] for a filament spooler.
G28 X
G90
MANUAL_STEPPER STEPPER=stepper_spool ENABLE=1 SET_POSITION=0
G1 X0 F300
SDCARD_LOOP_BEGIN COUNT=2
MANUAL_STEPPER STEPPER=stepper_spool ENABLE=1 MOVE=9000 SPEED=360 SYNC=0
G1 X43.25 F105
G1 X0 F105
SDCARD_LOOP_END
MANUAL_STEPPER STEPPER=stepper_spool ENABLE=1 MOVE=360 SPEED=120 SYNC=0
G1 X1.75 F35
G1 X3.5 F35
G28 X
M84
But I always get Only permitted in SD file. as error.
And yes, the file to print is in the folder assigned with [virtual_sdcard]
Maybe the gcodes folder must be elsewhere?
Do I miss something in the gcode file?
The SDCARD_LOOP_BEGIN command must be in a gcode file that one is actively printing, and being printed using Klipper’s “virtual_sdcard” system. That is, the command can not be sent from the command-line, nor from macros issued from the command-line, nor from gcode sent piecemeal from OctoPrint. The error you posted above indicates that the sdcard_loop.py code detected the command did not originate from an active virtual_sdcard gcode print.
If the command was in a gcode file being actively printed from virtual_sdcard, then it indicates an error somewhere in the code. In that case, you could try issuing an M112 immediately after the event to get additional information in the Klipper log. I suspect a developer would need to look through that info to track down the root cause.
I actually print from a file that is located in the virtual SDcard path.
Here is the klippy log with an issued M112
klippy.log (111.7 KB)
Test_3.gcode (719 Bytes)
I’m not sure what frontend you are using, but the gcode commands were definitely sent via the /tmp/printer pseudo-tty and not from a virtual_sdcard print. If this is OctoPrint, make sure you are telling it to print via sdcard and not via its normal streaming mode.
From the log:
Read 10109.004722: 'N0 M110 N0*125\n'
Read 10109.032599: 'N1 G28 X*106\n'
Read 10112.363954: 'N2 G90*18\n'
Read 10112.368594: 'MANUAL_STEPPER STEPPER=stepper_spool ENABLE=1 SET_POSITION=0\n'
Read 10112.379977: 'N3 G1 X0 F300*54\n'
Read 10112.384958: 'SDCARD_LOOP_BEGIN COUNT=2\n'
Read 10112.483550: 'N4 M84*27\n'
Read 10115.878750: 'M105\n'
Read 10116.954991: 'M112\n'
Those “Read” reports are reporting data read from /tmp/printer.
If you are using Octoprint, then my experience is that Octoprint uses the traditional way via /tmp/printer and effectively bypasses the virtual SD card.
Try using M23 or Mainsail / fluidd.
Good to know.
When M23 does not work, I’ll go with Mainsail.
Thank you both
Just installed Moonraker/Mainsail via KIAUH and it works now.
Thanks a lot again
