Its possible use a PINDA v2
Printer Model: Ratrig Vcore 3
MCU / Printerboard: Octopus Pro
Not a Issue…
I have see there are leveling sensors that incorporate a thermistor to correct the temperature, it seems that they are the ones used by some PRUSA… Can this type of sensor, 4 wires, be used with Klipper?
If is yes. How would it be wired and configured?
Thank you
Klipper doesn’t support that temperature compensation (yet?).
If you instead get a SuperPINDA/SupCRprobe, it has the temperature compensation built into the probe itself instead, so no correction is needed by Klipper.
Ok… But can be used with 3 pin?
It can be used without the thermistor pins, you just get no compensation and likely bad readings if you are using an enclosure.
