Klipper Docker Questions
Printer Model: Custom
MCU / Printerboard: BTT Octopus + CR10 + Nano
Host / SBC: Rpi 3 Rev B
klippy.log: NA
I am working on making a docker container for installing firmware on 3 boards on a custom printer that will eventually be a production model. The boards I am trying to flash are BTT Octopus, a CR10, and an arduino nano.
We seem to be having an issue with avrdude.
Below is the command I run, and the following error. Has anyone encountered this before, or have any suggestions to help troubleshoot this?
$ docker compose -f docker-compose.extra.make.yaml run --rm make flash FLASH_DEVICE=/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Creating symbolic link out/board
Building out/autoconf.h
Compiling out/src/sched.o
Compiling out/src/command.o
Compiling out/src/basecmd.o
Compiling out/src/debugcmds.o
Compiling out/src/initial_pins.o
Compiling out/src/gpiocmds.o
Compiling out/src/stepper.o
Compiling out/src/endstop.o
Compiling out/src/trsync.o
Compiling out/src/adccmds.o
Compiling out/src/spicmds.o
Compiling out/src/i2ccmds.o
Compiling out/src/pwmcmds.o
Compiling out/src/buttons.o
Compiling out/src/tmcuart.o
Compiling out/src/neopixel.o
Compiling out/src/pulse_counter.o
Compiling out/src/lcd_st7920.o
Compiling out/src/lcd_hd44780.o
Compiling out/src/spi_software.o
Compiling out/src/i2c_software.o
Compiling out/src/thermocouple.o
Compiling out/src/sensor_adxl345.o
Compiling out/src/sensor_angle.o
Compiling out/src/sensor_mpu9250.o
Compiling out/src/sensor_lis2dw.o
Compiling out/src/sensor_ldc1612.o
src/sensor_ldc1612.c: In function 'ldc1612_query':
src/sensor_ldc1612.c:143:35: warning: left shift count >= width of type [-Wshift-count-overflow]                                  uint32_t data = (d[0] << 24L) | (d[1] << 16L) | (d[2] << 8) | d[3];        ^
src/sensor_ldc1612.c:143:51: warning: left shift count >= width of type [-Wshift-count-overflow]                                  uint32_t data = (d[0] << 24L) | (d[1] << 16L) | (d[2] << 8) | d[3];        ^
Compiling out/src/sensor_bulk.o
Compiling out/src/avr/main.o
Compiling out/src/avr/timer.o
Compiling out/src/avr/gpio.o
Compiling out/src/avr/adc.o
Compiling out/src/avr/spi.o
Compiling out/src/avr/i2c.o
Compiling out/src/avr/hard_pwm.o
Compiling out/src/avr/watchdog.o
Compiling out/src/avr/serial.o
Compiling out/src/generic/serial_irq.o
Building out/compile_time_request.o
Version: ?-20240530_211938-0be72d01654b
Linking out/klipper.elf
Creating hex file out/klipper.elf.hex
Flashing out/klipper.elf.hex to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 via avrdude
avrdude error: timeout
avrdude error: timeout communicating with programmer
avrdude error: unable to open programmer wiring on port /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
avrdude done.  Thank you.
make: *** [src/avr/Makefile:34: flash] Error 1
Please, when you upload code snippets, either do it as file or use the Preformatted Text feature of the forum editor:
Format
It’s better to read and no information gets lost
Firs of all you need to explain which Host system you use and which Docker, provide some data how you are running docker, etc …
Then maybe it would be possible to pass USB from Host to container - it’s not always possible.
For example for “Docker desktop” - it’s stated that it’s impossible
