Klipper etc on Apline with openrc?
Printer Model:
MCU / Printerboard:
Hello, Sorry if this has been already discussed. Does anyone know if klipper, moonraker, mainsail, and klipperscreen can run on a Apline OS using openrc instead of systemd? Or are they dependent on systemd? Specifically on a phone running postmarketOS? Thanks in advance.
No specific dependencies.
But you are on your own generally.
Thanks, I found a script that should install and create rc services:
This should cover everything except klipperscreen. Klipperscreen says it creates a systemd service but I wonder if there is a way around that, I can probably edit the install script.
