Printer Model: Voron 2.4r2 250mm with Voron Tap
MCU / Printerboard: BTT Octopus Max EZ with 6 EZ2209 and BTT EBB SB2209 CAN (STM32)
Host / SBC: Check neofetch below, board is a ASRock AD2550-ITX
neofetch
OS: Ubuntu 24.04.1 LTS x86_64
Kernel: 6.8.0-49-generic
Uptime: 55 mins
Packages: 896 (dpkg)
Shell: fish 3.7.0
Terminal: /dev/pts/3
CPU: Intel Atom D2550 (4) @ 1.866GHz
GPU: Intel Atom Processor D2xxx/N2xxx
Memory: 486MiB / 7928MiB
After some time using my EBB SB2209 (RP2040) via USB I decided to switch over to canbus. The reason being, that I intend to also wire my SuperRacer, my Voron 0.2 and my (soon to be built) Rook 2020 MK2 via CAN to reduce the cables needed in my host PC.
The first issue I had was getting the SB2209 (RP2040) to be recognized at all by Klipper and simply gave up. My dad had a EBB SB2209 (STM32) which gets recognized and was able to get flashed. I managed to connect it with klipper and get two can uuids listed using the query tool. But as soon as I start the klipper service it ends with the following message:
mcu 'mcu': Starting CAN connect
Created a socket
webhooks client 135305606483072: New connection
webhooks client 135305606483072: Client info {'program': 'Moonraker', 'version': 'v0.9.3-1-g4e00a07'}
Loaded MCU 'mcu' 120 commands (v0.12.0-394-g7f89668d6 / gcc: (15:13.2.rel1-2) 13.2.1 20231009 binutils: (2.42-1ubuntu1+23) 2.42)
MCU 'mcu' config: ADC_MAX=4095 BUS_PINS_i2c1_PB6_PB7=PB6,PB7 BUS_PINS_i2c1_PB8_PB9=PB8,PB9 BUS_PINS_i2c2_PB10_PB11=PB10,PB11 BUS_PINS_i2c3_PA8_PC9=PA8,PC9 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi3a=PC11,PC12,PC10 BUS_PINS_spi4=PE13,PE14,PE12 BUS_PINS_spi5=PF8,PF9,PF7 BUS_PINS_spi5a=PH7,PF11,PH6 BUS_PINS_spi6=PG12,PG14,PG13 CANBUS_BRIDGE=1 CLOCK_FREQ=400000000 INITIAL_PINS=PF7 MCU=stm32h723xx PWM_MAX=255 RECEIVE_WINDOW=192 RESERVE_PINS_CAN=PD0,PD1 RESERVE_PINS_USB=PA11,PA12 RESERVE_PINS_crystal=PH0,PH1 STATS_SUMSQ_BASE=256 STEPPER_BOTH_EDGE=1
mcu 'EBBCan': Starting CAN connect
Created a socket
mcu 'EBBCan': got {'count': 559, 'sum': 541734, 'sumsq': 5133552, '#name': 'stats', '#sent_time': 3401.948837832, '#receive_time': 3401.99062775}
Loaded MCU 'EBBCan' 120 commands (v0.12.0-394-g7f89668d6 / gcc: (15:13.2.rel1-2) 13.2.1 20231009 binutils: (2.42-1ubuntu1+23) 2.42)
MCU 'EBBCan' config: ADC_MAX=4095 BUS_PINS_i2c1_PA9_PA10=PA9,PA10 BUS_PINS_i2c1_PB6_PB7=PB6,PB7 BUS_PINS_i2c1_PB8_PB9=PB8,PB9 BUS_PINS_i2c2_PB10_PB11=PB10,PB11 BUS_PINS_i2c2_PB13_PB14=PB13,PB14 BUS_PINS_i2c3_PB3_PB4=PB3,PB4 BUS_PINS_i2c3_PC0_PC1=PC0,PC1 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2_PB2_PB11_PB10=PB2,PB11,PB10 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi3=PB4,PB5,PB3 CANBUS_FREQUENCY=1000000 CLOCK_FREQ=64000000 MCU=stm32g0b1xx PWM_MAX=255 RECEIVE_WINDOW=192 RESERVE_PINS_CAN=PB0,PB1 RESERVE_PINS_crystal=PF0,PF1 STATS_SUMSQ_BASE=256 STEPPER_BOTH_EDGE=1
Sending MCU 'mcu' printer configuration...
Configured MCU 'mcu' (1024 moves)
Sending MCU 'EBBCan' printer configuration...
b'Got error -1 in can write: (11)Resource temporarily unavailable'
b'Halting reads due to CAN write errors.'
This happens, regardles, which bitrate I use, I tried 1M, 250K and 500K. All three yield the same result. For me it looks like it actually connects to the board, otherwise it wouldn’t know the board details, but after that it stops.
The wire is the original one from BTT just shortend to the length I actually need. But it didn’t work with the long cable either.
Can anyone help me troubleshoot and hopefully find a solution?
klippy.log (23.8 KB)
Output of can query
> ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0voron2
Found canbus_uuid=88067de26298, Application: Klipper
Found canbus_uuid=3857b6afa202, Application: Klipper
Total 2 uuids found
The network is configured as follows:
> cat /etc/network/interfaces.d/can0voron2
allow-hotplug can0voron2
iface can0voron2 can static
bitrate 1000000
up ip link set $IFACE txqueuelen 1024
pre-up ip link set can0voron2 type can bitrate 1000000
pre-up ip link set can0voron2 txqueuelen 1024
> cat /etc/systemd/network/10-can.link
[Match]
Type=can
[Link]
TransmitQueueLength=1024
> cat /etc/systemd/network/25-can.network
[Match]
Name=can*
[CAN]
BitRate=1M
The can interface is renamed using udev like this:
> cat /etc/udev/rules.d/z21_persistent-local.rules
SUBSYSTEM=="net", ACTION=="add", ATTRS{serial}=="380036001551303531313638", NAME="can0voron2"
Here are the guides I followed to get all that setup:
