Klipper reports: ERROR
Printer Model: Voron 2.4 R2
MCU / Printerboard: Octopus Pro STM32F446
… It was fine, until I decided to bring my printer offline to install PT1000 as a chamber thermistor, redo or just upgrade some mods into my printer like adding a piano wire so that the wire won’t jiggle, etc.
I made sure the wires are correctly oriented but oh boy, I’m out of options. Please help
klippy.log (130.7 KB)
moonraker.log (31.0 KB)
Hello @Shazklebolt !
You may check another time the CAN connection to the MCU:
serialhdl.error: mcu 'mcu': Unable to connect
Are you sure the metal won’t influence the connection capabilities for the CAN cable?
I suspect the issue may be with the controller board, but I may be wrong, as all I did was disconnect my RJ 11 to the CAN cable, and my 3D printer turned off after I turned the host off.
Here are the steps I took:
  1. I cleaned up my piano wire attached to the PG7 connector and my SB. It was messy before, so I cut it into the right length and added a clip for support. I am sure it won’t affect the connection capabilities of the CAN cable.
  2. I organised the wires in my Z cable chain, which included the CAN cable, A + B motor wires, and Y-axis cable.
  3. I tightened the belts running through my X carriage, as they were 4 to 6 grooves short.
  4. I performed a gantry deracking.
I did some troubleshooting, and I hope this information is helpful. I disconnected the CAN cable linked to my EBB SB2209 CAN board (RP2040) for my Stealthburner. Then, I entered my PuTTY terminal and entered a command, resulting in an error.
Finding the canbus_uuid for new micro-controllers
Result
biqu@BTT-CB1:~$ ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0
  File "/home/biqu/klipper/scripts/canbus_query.py", line 64, in <module>
    main()
  File "/home/biqu/klipper/scripts/canbus_query.py", line 61, in main
    query_unassigned(canbus_iface)
  File "/home/biqu/klipper/scripts/canbus_query.py", line 20, in query_unassigned
    bus = can.interface.Bus(channel=canbus_iface, can_filters=filters,
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/can/interface.py", line 127, in __new__
    return cls(channel, *args, **kwargs)
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/can/interfaces/socketcan/socketcan.py", line 594, in __init__
    bind_socket(self.socket, channel)
  File "/home/biqu/klippy-env/lib/python3.9/site-packages/can/interfaces/socketcan/socketcan.py", line 459, in bind_socket
    sock.bind((channel,))
OSError: [Errno 19] No such device
Also, I think it should be
biqu@BTT-CB1:~$ ~/klippy-env/bin/python~/klipper/scripts/canbus_query.py can0
Total 0 uuids found
Instead of the above error correct?
I hope this information is useful. Thanks for the reply @EddyMI3D
It looks like that the CAN interface on the host side is not working, i.e. Linux is not exposing the can0 interface.
Check against CANBUS - Klipper documentation
