Hello all fantastic work on all this I have managed to set everything up and have it all working. I have a noob question. using @Function3D cofig and macros using the unload filament macro just extruded filament and dose not release it like the default AC merlin firmware is this normal and i just need to cut the filament then extrude the remainder or should it unload it like the default system. Thx again all involved.
I have never used those macros, I have revised them and simplified them, replace them in the macros.cfg file with these ones
[gcode_macro LOAD_FILAMENT]
{% set speed = params.SPEED|default(180) %}
SAVE_GCODE_STATE NAME=load_state
M300 # beep
G91
G92 E0
M104 S245 ; set extruder temp
M109 S245 ; wait for extruder temp
G1 E120 F{speed} # purge
M300
M300
M104 S0
RESTORE_GCODE_STATE NAME=load_state
[gcode_macro UNLOAD_FILAMENT]
SAVE_GCODE_STATE NAME=unload_state
G91
M300 # beep
G92 E0
G1 E20 F{speed}
G1 E-80 F{speed}
M300
M300
M104 S0
RESTORE_GCODE_STATE NAME=unload_state
@Function3D maybe you can help me again. i donāt get any usb output at all. sorry my english is real, so i have to work with translator
do you have any ideas what else i could do?
Thank you very much, that looks very promising - Iāll test it this evening.
Please stick to the English language as we are an English speaking forum here.
Compare the output of āls /devā with the printer powered on and plugged in and unplugged, use that as the path for the path in your printer.cfg
You mean after fix which @dockertj posted? Because currently ls /dev/ doesnāt output anything.
The device is created in ā/devā, āls /devā should list many devices and a new one when you plug in the printer, that path to the new one is the one you can use bypassing the bug that does not create symbolic links in ā/dev/serial/by-pathā.
Hi my friend, thank you for all your work.
I have a small doubt, if I want the kinematics to be CoreXY, do I change that in Printer.cfg only or do I have to do something on the firmware as well?
I know I can just do a Cartesian cube (like ender 5 s1) but I want to try making this a CoreXY without changing the motherboard.
I bought a couple of used Kobra 2 and Iām bored so this will be my next project.
Thanks in advance.
This printer is a bed slinger. You cannot change it into a CoreXY
Very complex task, your minor problem will be the changes in the printer.cfg, you will need additional hardware most probably and create a completely new structure with those two printers, I really have no idea how to do it and I donāt think itās a good idea
As people have said, youāre starting with a bed slinger which doesnāt lend itself to the CoreXY architecture very easily.
However, if youāre looking to learn more about different approaches to 3D printers, why donāt you try to make it into a CoreXZ printer?
Like building a Ferrari out of a Fiat?
- Disassemble the Fiat to the last screw
- Throw away 99.9% of the Fiat parts
- Order 99.9% of the needed Ferrari parts
- Build a Ferrari utilizing 0.1% of the Fiat parts
- Apply a sticker that reads āThis Ferrari consists of reused Fiat partsā
SCNR
I HATE car analogies because theyāre always wrong, generally self serving and tend to be used to put somebody else down.
Regardless, based on what I see here, I would not consider a Kobra 2 to be a āFerrariā (apologies to any Kobra 2 owners that are happy with their printers).
The point was that @FherraZ indicated that he had bought a couple of used Kobra 2s, was āboredā with them and was asking what he could do to change them. Going from a bed slinger to a CoreXY would require basically throwing away all the mechanical pieces while going with a CoreXZ could use the base mechanical hardware, would require replacing the gantry with some specialized pieces and could be an interesting project.
Iāve been busy lately but I am designing the carriages, Iāll try to make 2 versions if possible, one using the motion system already in place integrating the Y gantry from the 2 printers into Y CoreXY movement and living the X as it is with the mods necessary for the new belt motion.
The other one I will try to design with some 8mm smooth rods I have from an old i3.
The Z for both will probably be a mix between the original Kobra 2 Z that already is in place but with the proper adjustments, and I will add an extra rod and screw at the back for a 3 point Z bed.
Hi, Iām using this config with OrcaSlicer, but I get this error: Unknown command:"M420".
Reading on internet it looks like itās to load the bed mesh.
Iām having some problems printing (incongruency in the first layer, some zones are too squished, other are fine) so I have the doubt that itās actually not loading the bed mesh.
Anyone can help me?
No, it doesnāt: G-code - RepRap
Neither with Klipper nor with Marlin.
Yes it does with Marlin - just read the paragraph below the one you actually linked to (because you linked to MachineKit) and/or read here: Bed Leveling State | Marlin Firmware
However, M420 doesnāt work with Klipper, so @CtrlValCanc you have to load the bedmesh profile as mentioned here: Bed Mesh - Klipper documentation - best would be to read the whole chapter about Klipperās bedmesh.
Also make sure to have the x-gantry trammed, so that itās parallel to the bed itself: Axes - Kobra2 Insights
Also check the frame and see if the Y-axis rail is trammed as well.
If you have everything done, always let the bed settle being heated up for ~15min (the longer the better) before actually probing a mesh or starting a print.
If you then still have certain spots or areas where you have ādentsā and the ABL doesnāt 100% cope with that, you can add Kapton tape on the magnetic foil to equalize the surface.
