Klipper Internal error on command:"G1"
Is this at the endstop or is the toolhead coming in contact with the printer’s frame?
If this is the case, then you could have a power glitch that is causing your problem.
There is no end stop at this location and x carriage is absolutely free on full length of x carriage.
Considering this fact I have replaced Smps with 20 Amps . And change Pi power supply also but no improvement.
I have created gcode file to identify problem source , it moves x carriage from 0 to 200. And Came back to 0. Then moves y gantry 1mm. This cycle repeats till y axis reaches 200. After that y gantry movement decrease for 1mm after every one cycle of x movement and reach to x ,& y at zero.
After running test g code plenty of time i suspect problem associate with x carriage movement only.
As machine halted during x movement only.
Initially i have doubt on heater cable, but test g code runs only x & y steppers so problem is most with x carriage only.
My next step is to run x & y carriage individually for number of times which gives more insight.
Raspberry Pi and MCU replacement is last pending steps.
Nope. I have removed webcan.
You get a “b’Got EOF when reading from device’” in both attached klippy.logs
before “Timeout with MCU ‘mcu’ (eventtime=xxxx.xxxxxx)” is issued.
Don’t know how to interpret that.
There is a Knowledge Base article https://klipper.discourse.group/t/got-eof-when-reading-from-device, but I think you already checked everything mentioned in the article.
One thing you didn’t try yet. How old is your SDcard?
I would give it a try with a fresh one. You can easily clone your old card to a new one with the “dd” command under Linux and start the print again.
SD card is Is approx 1 year old. I have one new card laying arround so I will replace it and update.
I have tried my sample G code on 29th April and surprisingly works without Disconnecting mcu.
I ran that g code approx. 5 to 7 time but machine run without any problem.
Then i have re flashed Pi & used fresh SanDisk sd card.
Run 12 hours print two times. I.e. 24 hour running time in 3 days. Machine working fine without Disconnecting mcu. (Machine running without filament)
I don’t know watheer sd cards created that fault or not.
Well , let’s see what happened on my next print.
Do I get that right, that you used the sdcard you used, when having troubles?
Could you please post klippy.logs from both scenarios?
Logs of old SD card
Old SD Log.zip (1.4 MB)
Logs of new SD card
New SD Log.zip (31.7 KB)
Nope since first time i faced problem i have not used webcam.
again printer stopped with MCU disconnecting fault. this time klipper is running wiht new card.
recent log is attached.
klippy.log (3.3 MB)
this Geode file is running while machine stopped.
X_Y_check.gcode.zip (268 Bytes)
i have uploaded klipper log on klipper log analyzer klipper log analyzer which result is as below.
MCU utilization is showing more then 100% while MCU disconnected as per below image.
Sorry, that was a stupid question from my side. Your klippy.logs show, that you didn’t use your webcam.
Don’t know that application. I use “Graph Klipper Stats”, the original. We might ask Sineos, if that is legit.
All your klippy.logs show “Virtual sdcard” entries, except “New SD Log.zip” from “May 2, 6:27 PM” where no error occurred. Really hard to interpret.
Search "Virtual sdcard" (1 hit in 1 file of 1 searched)
  H:\3d_cheap_piece_of_crap\klipper_hcet14\forum\klipper-internal-error-on-command-g1\klippy_logs\6\klippy.log (1 hit)
	Line 8587: Virtual sdcard (725): '0000\ng1\tx\t0\ty\t16\tf50000\ng1\tx\t200\ty\t17\tf50000\ng1\tx\t0\ty\t17\tf50000\ng1\tx\t200\ty\t18\tf50000\ng1\tx\t0\ty\t18\tf50000\ng1\tx\t200\ty\t19\tf50000\ng1\tx\t0\ty\t19\tf50000\ng1\tx\t200\ty\t20\tf50000\ng1\tx\t0\ty\t20\tf50000\ng1\tx\t200\ty\t21\tf50000\ng1\tx\t0\ty\t21\tf50000\ng1\tx\t200\ty\t22\tf50000\ng1\tx\t0\ty\t22\tf50000\ng1\tx\t200\ty\t23\tf50000\ng1\tx\t0\ty\t23\tf50000\ng1\tx\t200\ty\t24\tf50000\ng1\tx\t0\ty\t24\tf50000\ng1\tx\t200\ty\t25\tf50000\ng1\tx\t0\ty\t25\tf50000\ng1\tx\t200\ty\t26\tf50000\ng1\tx\t0\ty\t26\tf50000\ng1\tx\t200\ty\t27\tf50000\ng1\tx\t0\ty\t27\tf50000\ng1\tx\t200\ty\t28\tf50000\ng1\tx\t0\ty\t28\tf50000\ng1\tx\t200\ty\t29\tf50000\ng1\tx\t0\ty\t29\tf50000\ng1\tx\t200\ty\t30\tf50000\ng1\tx\t0\ty\t30\tf50000\ng1\tx\t200\ty\t31\tf50000\ng1\tx\t0\ty\t31\tf50000\ng1\tx\t200\ty\t32\tf50000\ng1\tx\t0\ty\t32\tf50000\ng1\tx\t200\ty\t33\tf50000\ng1\tx\t0\ty\t33\tf50000\ng1\tx\t200\ty\t34\tf50000\ng1\tx\t0\ty\t34\tf50000\ng1\tx\t200\ty\t35\tf50000\ng1\tx\t0\ty\t35\tf50000\ng1\tx\t200\ty\t36\tf50000\ng1\tx\t0\ty\t36\tf50000\ng1\tx\t200\ty\t37\tf50000\ng1\tx\t0\ty\t37\tf50000\ng1\tx\t200\ty\t38\tf50000\ng1\tx\t0\ty\t38\tf50000\ng1\tx\t200\ty\t39\tf50000\ng1\tx\t0\ty\t39\tf50000\ng1\tx\t200\ty\t40\tf50000\ng1\tx\t0\ty\t40\tf50000\ng1\tx\t200\ty\t41\tf50000\ng1\tx\t0\ty\t41\tf50000\n'
Search "Virtual sdcard" (0 hits in 0 files of 1 searched)
Search "Virtual sdcard" (3 hits in 1 file of 1 searched)
  H:\3d_cheap_piece_of_crap\klipper_hcet14\forum\klipper-internal-error-on-command-g1\klippy_logs\4\klippy (4).log (3 hits)
	Line 29752: Virtual sdcard (772258): '1\nG1 X171.142 Y15.096 E.09141\nG1 X172.35 Y16 E.06321\nG1 X173.699 Y17.209 E.0759\nG1 X175.121 Y18.784 E.0889\nG1 X176.013 Y19.99 E.06285\nG1 X176.955 Y21.536 E.07585\nG1 X177.742 Y23.166 E.07584\nG1 X178.429 Y25.061 E.08445\nG1 X201.614 Y106.174 E3.53453\nG1 X201.85 Y107.334 E.0496\nG1 X201.907 Y107.937 E.02538\nG1 X201.901 Y111.69 E.15724\nG1 X197.904 Y180.809 E2.90075\nG1 X197.604 Y182.872 E.08734\nG1 X197.248 Y184.341 E.06333\nG1 X196.668 Y186.06 E.07601\nG1 X195.928 Y187.717 E.07603\nG1 X194.869 Y189.55 E.08869\nG1 X193.805 Y191.02 E.07603\nG1 X192.815 Y192.162 E.06332\nG1 X191.512 Y193.425 E.07603\nG1 X190.095 Y194.558 E.07601\nG1 X188.576 Y195.551 E.07603\nG1 X186.97 Y196.395 E.07601\nG1 X185.291 Y197.083 E.07602\nG1 X183.554 Y197.608 E.07603\nG1 X181.475 Y198.008 E.0887\nG1 X179.683 Y198.166 E.07537\nG1 X120.267 Y198.42 E2.4894\nG1 E-.56 F3600\n;WIPE_START\nG1 F7200\nG1 X120.207 Y198.421 E-.0285\nG1 X119.762 Y198.423 E-.2115\n;WIPE_END\n; printing object MirabaiMQOR.stl id:0 copy 0\nEXCLUDE_OBJECT_START NAME=MirabaiMQOR_stl_id_0_copy_0\n'
	Line 33270: Virtual sdcard (69198): 'X55.076 Y42.802 E3.17982\nG1 X55.255 Y42.675 E.00648\nG1 X55.319 Y42.622 E.00243\nG1 X55.578 Y42.383 E.0104\nG1 X162.756 Y42.383 E3.15888\nG1 X162.548 Y41.964 E.01379\nM73 P0 R1236\nG1 X55.998 Y41.964 E3.14035\nG1 X56.224 Y41.716 E.00988\nG1 X56.384 Y41.545 E.00691\nG1 X163.614 Y41.545 E3.1604\nG1 X164.046 Y41.427 E.01317\nG1 E-2.8 F3600\n;WIPE_START\nG1 F900\nG1 X163.614 Y41.545 E-.53622\nG1 X163.061 Y41.545 E-.66378\n;WIPE_END\nG1 Z.6 F9000\nG1 X170.47 Y50.88 Z.6\nG1 Z.2\nG1 E4 F2400\nG1 F900\nG1 X170.329 Y50.865 E.00419\nG1 X170.298 Y50.762 E.00315\nG1 X46.637 Y50.762 E3.64468\nG1 X46.76 Y50.627 E.00538\nG1 X46.777 Y50.609 E.00073\nG1 X46.874 Y50.51 E.00408\nG1 X47.02 Y50.343 E.00654\nG1 X170.174 Y50.343 E3.62974\nG1 X170.132 Y50.2 E.00439\nG1 X170.122 Y50.168 E.00099\nG1 X170.037 Y49.924 E.00761\nG1 X47.39 Y49.924 E3.61478\nG1 X47.642 Y49.647 E.01105\nG1 X47.765 Y49.505 E.00552\nG1 X169.837 Y49.505 E3.59781\nG1 X169.739 Y49.312 E.00638\nG1 X169.7 Y49.245 E.00229\nG1 X169.597 Y49.086 E.00558\nG1 X48.154 Y49.086 E3.5793\nG1 X48.559 Y48.667 E.01719\n'
	Line 35515: Virtual sdcard (68708): '223 Y40.707 E.00136\nG1 X165.975 Y40.707 E3.20526\nG1 X166.216 Y40.587 E.00794\nG1 E-2.8 F3600\n;WIPE_START\nG1 F900\nG1 X165.975 Y40.707 E-.32316\nG1 X165.244 Y40.707 E-.87684\n;WIPE_END\nG1 Z.6 F9000\nG1 X163.268 Y43.64 Z.6\nG1 Z.2\nG1 E4 F2400\nG1 F900\nG1 X53.95 Y43.64 E3.22191\nG1 X54.191 Y43.433 E.00934\nG1 X54.234 Y43.4 E.0016\nG1 X54.478 Y43.221 E.00893\nG1 X163.151 Y43.221 E3.20291\nG1 X163.149 Y43.217 E.00012\nG1 X163.01 Y42.894 E.01034\nG1 X162.993 Y42.859 E.00116\nG1 X162.965 Y42.802 E.00188\nG1 X55.076 Y42.802 E3.17982\nG1 X55.255 Y42.675 E.00648\nG1 X55.319 Y42.622 E.00243\nG1 X55.578 Y42.383 E.0104\nG1 X162.756 Y42.383 E3.15888\nG1 X162.548 Y41.964 E.01379\nM73 P0 R1236\nG1 X55.998 Y41.964 E3.14035\nG1 X56.224 Y41.716 E.00988\nG1 X56.384 Y41.545 E.00691\nG1 X163.614 Y41.545 E3.1604\nG1 X164.046 Y41.427 E.01317\nG1 E-2.8 F3600\n;WIPE_START\nG1 F900\nG1 X163.614 Y41.545 E-.53622\nG1 X163.061 Y41.545 E-.66378\n;WIPE_END\nG1 Z.6 F9000\nG1 X170.47 Y50.88 Z.6\nG1 Z.2\nG1 E4 F2400\nG1 F900\nG1 X170.329 Y50.865 E.00419\nG1 X170.298 Y50.762 E.00315\n'
Search "Virtual sdcard" (7 hits in 1 file of 1 searched)
  H:\3d_cheap_piece_of_crap\klipper_hcet14\forum\klipper-internal-error-on-command-g1\klippy_logs\3\Unconfirmed 997167.crdownload (7 hits)
	Line  3844: Virtual sdcard (9303): '\t0\ty\t176\tf50000\ng1\tx\t200\ty\t175\tf50000\ng1\tx\t0\ty\t175\tf50000\ng1\tx\t200\ty\t174\tf50000\ng1\tx\t0\ty\t174\tf50000\ng1\tx\t200\ty\t173\tf50000\ng1\tx\t0\ty\t173\tf50000\ng1\tx\t200\ty\t172\tf50000\ng1\tx\t0\ty\t172\tf50000\ng1\tx\t200\ty\t171\tf50000\ng1\tx\t0\ty\t171\tf50000\ng1\tx\t200\ty\t170\tf50000\ng1\tx\t0\ty\t170\tf50000\ng1\tx\t200\ty\t169\tf50000\ng1\tx\t0\ty\t169\tf50000\ng1\tx\t200\ty\t168\tf50000\ng1\tx\t0\ty\t168\tf50000\ng1\tx\t200\ty\t167\tf50000\ng1\tx\t0\ty\t167\tf50000\ng1\tx\t200\ty\t166\tf50000\ng1\tx\t0\ty\t166\tf50000\ng1\tx\t200\ty\t165\tf50000\ng1\tx\t0\ty\t165\tf50000\ng1\tx\t200\ty\t164\tf50000\ng1\tx\t0\ty\t164\tf50000\ng1\tx\t200\ty\t163\tf50000\ng1\tx\t0\ty\t163\tf50000\ng1\tx\t200\ty\t162\tf50000\ng1\tx\t0\ty\t162\tf50000\ng1\tx\t200\ty\t161\tf50000\ng1\tx\t0\ty\t161\tf50000\ng1\tx\t200\ty\t160\tf50000\ng1\tx\t0\ty\t160\tf50000\ng1\tx\t200\ty\t159\tf50000\ng1\tx\t0\ty\t159\tf50000\ng1\tx\t200\ty\t158\tf50000\ng1\tx\t0\ty\t158\tf50000\ng1\tx\t200\ty\t157\tf50000\ng1\tx\t0\ty\t157\tf50000\ng1\tx\t200\ty\t156\tf50000\ng1\tx\t0\ty\t156\tf50000\ng1\tx\t200\ty\t155\tf50000\ng1\tx\t0\ty\t155\tf50000\ng1\tx\t200\ty\t154\tf50000\ng1\tx\t0\ty\t154\tf50000\ng1\tx\t200\ty\t153\tf50000\ng1\tx\t0\ty\t153\tf50000\ng1\tx\t200\ty\t152\tf50000\ng1\tx\t0\ty\t152\tf50000\n'
	Line 11119: Virtual sdcard (3171): '1\tx\t0\ty\t77\tf50000\ng1\tx\t200\ty\t78\tf50000\ng1\tx\t0\ty\t78\tf50000\ng1\tx\t200\ty\t79\tf50000\ng1\tx\t0\ty\t79\tf50000\ng1\tx\t200\ty\t80\tf50000\ng1\tx\t0\ty\t80\tf50000\ng1\tx\t200\ty\t81\tf50000\ng1\tx\t0\ty\t81\tf50000\ng1\tx\t200\ty\t82\tf50000\ng1\tx\t0\ty\t82\tf50000\ng1\tx\t200\ty\t83\tf50000\ng1\tx\t0\ty\t83\tf50000\ng1\tx\t200\ty\t84\tf50000\ng1\tx\t0\ty\t84\tf50000\ng1\tx\t200\ty\t85\tf50000\ng1\tx\t0\ty\t85\tf50000\ng1\tx\t200\ty\t86\tf50000\ng1\tx\t0\ty\t86\tf50000\ng1\tx\t200\ty\t87\tf50000\ng1\tx\t0\ty\t87\tf50000\ng1\tx\t200\ty\t88\tf50000\ng1\tx\t0\ty\t88\tf50000\ng1\tx\t200\ty\t89\tf50000\ng1\tx\t0\ty\t89\tf50000\ng1\tx\t200\ty\t90\tf50000\ng1\tx\t0\ty\t90\tf50000\ng1\tx\t200\ty\t91\tf50000\ng1\tx\t0\ty\t91\tf50000\ng1\tx\t200\ty\t92\tf50000\ng1\tx\t0\ty\t92\tf50000\ng1\tx\t200\ty\t93\tf50000\ng1\tx\t0\ty\t93\tf50000\ng1\tx\t200\ty\t94\tf50000\ng1\tx\t0\ty\t94\tf50000\ng1\tx\t200\ty\t95\tf50000\ng1\tx\t0\ty\t95\tf50000\ng1\tx\t200\ty\t96\tf50000\ng1\tx\t0\ty\t96\tf50000\ng1\tx\t200\ty\t97\tf50000\ng1\tx\t0\ty\t97\tf50000\ng1\tx\t200\ty\t98\tf50000\ng1\tx\t0\ty\t98\tf50000\ng1\tx\t200\ty\t99\tf50000\ng1\tx\t0\ty\t99\tf50000\ng1\tx\t200\ty\t100\tf50000\ng1\tx\t0\ty\t100\tf50000\ng1\tx\t200\ty\t101\tf50000\ng1\tx\t0\ty\t101\tf50000\ng1\tx\t200\ty\t102\tf50000\ng1\tx\t0\ty\t102\tf50000\n'
	Line 12289: Virtual sdcard (13607): '0000\ng1\tx\t0\ty\t72\tf50000\ng1\tx\t200\ty\t71\tf50000\ng1\tx\t0\ty\t71\tf50000\ng1\tx\t200\ty\t70\tf50000\ng1\tx\t0\ty\t70\tf50000\ng1\tx\t200\ty\t69\tf50000\ng1\tx\t0\ty\t69\tf50000\ng1\tx\t200\ty\t68\tf50000\ng1\tx\t0\ty\t68\tf50000\ng1\tx\t200\ty\t67\tf50000\ng1\tx\t0\ty\t67\tf50000\ng1\tx\t200\ty\t66\tf50000\ng1\tx\t0\ty\t66\tf50000\ng1\tx\t200\ty\t65\tf50000\ng1\tx\t0\ty\t65\tf50000\ng1\tx\t200\ty\t64\tf50000\ng1\tx\t0\ty\t64\tf50000\ng1\tx\t200\ty\t63\tf50000\ng1\tx\t0\ty\t63\tf50000\ng1\tx\t200\ty\t62\tf50000\ng1\tx\t0\ty\t62\tf50000\ng1\tx\t200\ty\t61\tf50000\ng1\tx\t0\ty\t61\tf50000\ng1\tx\t200\ty\t60\tf50000\ng1\tx\t0\ty\t60\tf50000\ng1\tx\t200\ty\t59\tf50000\ng1\tx\t0\ty\t59\tf50000\ng1\tx\t200\ty\t58\tf50000\ng1\tx\t0\ty\t58\tf50000\ng1\tx\t200\ty\t57\tf50000\ng1\tx\t0\ty\t57\tf50000\ng1\tx\t200\ty\t56\tf50000\ng1\tx\t0\ty\t56\tf50000\ng1\tx\t200\ty\t55\tf50000\ng1\tx\t0\ty\t55\tf50000\ng1\tx\t200\ty\t54\tf50000\ng1\tx\t0\ty\t54\tf50000\ng1\tx\t200\ty\t53\tf50000\ng1\tx\t0\ty\t53\tf50000\ng1\tx\t200\ty\t52\tf50000\ng1\tx\t0\ty\t52\tf50000\ng1\tx\t200\ty\t51\tf50000\ng1\tx\t0\ty\t51\tf50000\ng1\tx\t200\ty\t50\tf50000\ng1\tx\t0\ty\t50\tf50000\ng1\tx\t200\ty\t49\tf50000\ng1\tx\t0\ty\t49\tf50000\ng1\tx\t200\ty\t48\tf50000\ng1\tx\t0\ty\t48\tf50000\ng1\tx\t200\ty\t47\tf50000\ng1\tx\t0\ty\t47\tf50000\n'
	Line 14098: Virtual sdcard (4137): '\t0\ty\t101\tf50000\ng1\tx\t200\ty\t102\tf50000\ng1\tx\t0\ty\t102\tf50000\ng1\tx\t200\ty\t103\tf50000\ng1\tx\t0\ty\t103\tf50000\ng1\tx\t200\ty\t104\tf50000\ng1\tx\t0\ty\t104\tf50000\ng1\tx\t200\ty\t105\tf50000\ng1\tx\t0\ty\t105\tf50000\ng1\tx\t200\ty\t106\tf50000\ng1\tx\t0\ty\t106\tf50000\ng1\tx\t200\ty\t107\tf50000\ng1\tx\t0\ty\t107\tf50000\ng1\tx\t200\ty\t108\tf50000\ng1\tx\t0\ty\t108\tf50000\ng1\tx\t200\ty\t109\tf50000\ng1\tx\t0\ty\t109\tf50000\ng1\tx\t200\ty\t110\tf50000\ng1\tx\t0\ty\t110\tf50000\ng1\tx\t200\ty\t111\tf50000\ng1\tx\t0\ty\t111\tf50000\ng1\tx\t200\ty\t112\tf50000\ng1\tx\t0\ty\t112\tf50000\ng1\tx\t200\ty\t113\tf50000\ng1\tx\t0\ty\t113\tf50000\ng1\tx\t200\ty\t114\tf50000\ng1\tx\t0\ty\t114\tf50000\ng1\tx\t200\ty\t115\tf50000\ng1\tx\t0\ty\t115\tf50000\ng1\tx\t200\ty\t116\tf50000\ng1\tx\t0\ty\t116\tf50000\ng1\tx\t200\ty\t117\tf50000\ng1\tx\t0\ty\t117\tf50000\ng1\tx\t200\ty\t118\tf50000\ng1\tx\t0\ty\t118\tf50000\ng1\tx\t200\ty\t119\tf50000\ng1\tx\t0\ty\t119\tf50000\ng1\tx\t200\ty\t120\tf50000\ng1\tx\t0\ty\t120\tf50000\ng1\tx\t200\ty\t121\tf50000\ng1\tx\t0\ty\t121\tf50000\ng1\tx\t200\ty\t122\tf50000\ng1\tx\t0\ty\t122\tf50000\ng1\tx\t200\ty\t123\tf50000\ng1\tx\t0\ty\t123\tf50000\ng1\tx\t200\ty\t124\tf50000\ng1\tx\t0\ty\t124\tf50000\ng1\tx\t200\ty\t125\tf50000\ng1\tx\t0\ty\t125\tf50000\n'
	Line 15057: Virtual sdcard (2965): '0000\ng1\tx\t0\ty\t72\tf50000\ng1\tx\t200\ty\t73\tf50000\ng1\tx\t0\ty\t73\tf50000\ng1\tx\t200\ty\t74\tf50000\ng1\tx\t0\ty\t74\tf50000\ng1\tx\t200\ty\t75\tf50000\ng1\tx\t0\ty\t75\tf50000\ng1\tx\t200\ty\t76\tf50000\ng1\tx\t0\ty\t76\tf50000\ng1\tx\t200\ty\t77\tf50000\ng1\tx\t0\ty\t77\tf50000\ng1\tx\t200\ty\t78\tf50000\ng1\tx\t0\ty\t78\tf50000\ng1\tx\t200\ty\t79\tf50000\ng1\tx\t0\ty\t79\tf50000\ng1\tx\t200\ty\t80\tf50000\ng1\tx\t0\ty\t80\tf50000\ng1\tx\t200\ty\t81\tf50000\ng1\tx\t0\ty\t81\tf50000\ng1\tx\t200\ty\t82\tf50000\ng1\tx\t0\ty\t82\tf50000\ng1\tx\t200\ty\t83\tf50000\ng1\tx\t0\ty\t83\tf50000\ng1\tx\t200\ty\t84\tf50000\ng1\tx\t0\ty\t84\tf50000\ng1\tx\t200\ty\t85\tf50000\ng1\tx\t0\ty\t85\tf50000\ng1\tx\t200\ty\t86\tf50000\ng1\tx\t0\ty\t86\tf50000\ng1\tx\t200\ty\t87\tf50000\ng1\tx\t0\ty\t87\tf50000\ng1\tx\t200\ty\t88\tf50000\ng1\tx\t0\ty\t88\tf50000\ng1\tx\t200\ty\t89\tf50000\ng1\tx\t0\ty\t89\tf50000\ng1\tx\t200\ty\t90\tf50000\ng1\tx\t0\ty\t90\tf50000\ng1\tx\t200\ty\t91\tf50000\ng1\tx\t0\ty\t91\tf50000\ng1\tx\t200\ty\t92\tf50000\ng1\tx\t0\ty\t92\tf50000\ng1\tx\t200\ty\t93\tf50000\ng1\tx\t0\ty\t93\tf50000\ng1\tx\t200\ty\t94\tf50000\ng1\tx\t0\ty\t94\tf50000\ng1\tx\t200\ty\t95\tf50000\ng1\tx\t0\ty\t95\tf50000\ng1\tx\t200\ty\t96\tf50000\ng1\tx\t0\ty\t96\tf50000\ng1\tx\t200\ty\t97\tf50000\ng1\tx\t0\ty\t97\tf50000\n'
	Line 16876: Virtual sdcard (4515): '\t0\ty\t110\tf50000\ng1\tx\t200\ty\t111\tf50000\ng1\tx\t0\ty\t111\tf50000\ng1\tx\t200\ty\t112\tf50000\ng1\tx\t0\ty\t112\tf50000\ng1\tx\t200\ty\t113\tf50000\ng1\tx\t0\ty\t113\tf50000\ng1\tx\t200\ty\t114\tf50000\ng1\tx\t0\ty\t114\tf50000\ng1\tx\t200\ty\t115\tf50000\ng1\tx\t0\ty\t115\tf50000\ng1\tx\t200\ty\t116\tf50000\ng1\tx\t0\ty\t116\tf50000\ng1\tx\t200\ty\t117\tf50000\ng1\tx\t0\ty\t117\tf50000\ng1\tx\t200\ty\t118\tf50000\ng1\tx\t0\ty\t118\tf50000\ng1\tx\t200\ty\t119\tf50000\ng1\tx\t0\ty\t119\tf50000\ng1\tx\t200\ty\t120\tf50000\ng1\tx\t0\ty\t120\tf50000\ng1\tx\t200\ty\t121\tf50000\ng1\tx\t0\ty\t121\tf50000\ng1\tx\t200\ty\t122\tf50000\ng1\tx\t0\ty\t122\tf50000\ng1\tx\t200\ty\t123\tf50000\ng1\tx\t0\ty\t123\tf50000\ng1\tx\t200\ty\t124\tf50000\ng1\tx\t0\ty\t124\tf50000\ng1\tx\t200\ty\t125\tf50000\ng1\tx\t0\ty\t125\tf50000\ng1\tx\t200\ty\t126\tf50000\ng1\tx\t0\ty\t126\tf50000\ng1\tx\t200\ty\t127\tf50000\ng1\tx\t0\ty\t127\tf50000\ng1\tx\t200\ty\t128\tf50000\ng1\tx\t0\ty\t128\tf50000\ng1\tx\t200\ty\t129\tf50000\ng1\tx\t0\ty\t129\tf50000\ng1\tx\t200\ty\t130\tf50000\ng1\tx\t0\ty\t130\tf50000\ng1\tx\t200\ty\t131\tf50000\ng1\tx\t0\ty\t131\tf50000\ng1\tx\t200\ty\t132\tf50000\ng1\tx\t0\ty\t132\tf50000\ng1\tx\t200\ty\t133\tf50000\ng1\tx\t0\ty\t133\tf50000\ng1\tx\t200\ty\t134\tf50000\ng1\tx\t0\ty\t134\tf50000\n'
	Line 17905: Virtual sdcard (4221): '\t0\ty\t103\tf50000\ng1\tx\t200\ty\t104\tf50000\ng1\tx\t0\ty\t104\tf50000\ng1\tx\t200\ty\t105\tf50000\ng1\tx\t0\ty\t105\tf50000\ng1\tx\t200\ty\t106\tf50000\ng1\tx\t0\ty\t106\tf50000\ng1\tx\t200\ty\t107\tf50000\ng1\tx\t0\ty\t107\tf50000\ng1\tx\t200\ty\t108\tf50000\ng1\tx\t0\ty\t108\tf50000\ng1\tx\t200\ty\t109\tf50000\ng1\tx\t0\ty\t109\tf50000\ng1\tx\t200\ty\t110\tf50000\ng1\tx\t0\ty\t110\tf50000\ng1\tx\t200\ty\t111\tf50000\ng1\tx\t0\ty\t111\tf50000\ng1\tx\t200\ty\t112\tf50000\ng1\tx\t0\ty\t112\tf50000\ng1\tx\t200\ty\t113\tf50000\ng1\tx\t0\ty\t113\tf50000\ng1\tx\t200\ty\t114\tf50000\ng1\tx\t0\ty\t114\tf50000\ng1\tx\t200\ty\t115\tf50000\ng1\tx\t0\ty\t115\tf50000\ng1\tx\t200\ty\t116\tf50000\ng1\tx\t0\ty\t116\tf50000\ng1\tx\t200\ty\t117\tf50000\ng1\tx\t0\ty\t117\tf50000\ng1\tx\t200\ty\t118\tf50000\ng1\tx\t0\ty\t118\tf50000\ng1\tx\t200\ty\t119\tf50000\ng1\tx\t0\ty\t119\tf50000\ng1\tx\t200\ty\t120\tf50000\ng1\tx\t0\ty\t120\tf50000\ng1\tx\t200\ty\t121\tf50000\ng1\tx\t0\ty\t121\tf50000\ng1\tx\t200\ty\t122\tf50000\ng1\tx\t0\ty\t122\tf50000\ng1\tx\t200\ty\t123\tf50000\ng1\tx\t0\ty\t123\tf50000\ng1\tx\t200\ty\t124\tf50000\ng1\tx\t0\ty\t124\tf50000\ng1\tx\t200\ty\t125\tf50000\ng1\tx\t0\ty\t125\tf50000\ng1\tx\t200\ty\t126\tf50000\ng1\tx\t0\ty\t126\tf50000\ng1\tx\t200\ty\t127\tf50000\ng1\tx\t0\ty\t127\tf50000\n'
  H:\3d_cheap_piece_of_crap\klipper_hcet14\forum\klipper-internal-error-on-command-g1\klippy_logs\2\klippy (2).log (1 hit)
	Line 82511: Virtual sdcard (89154): '38 E4.92713\nG1 X192.083 Y109.419 E.01281\nG1 X24.756 Y109.419 E4.93165\nG1 X24.733 Y109 E.01237\nG1 X192.147 Y109 E4.9342\nG1 X192.184 Y108.628 E.01101\nG1 X192.183 Y108.581 E.00139\nG1 X24.73 Y108.581 E4.93536\nG1 X24.735 Y108.217 E.01072\nG1 X24.737 Y108.178 E.00117\nG1 X24.738 Y108.162 E.00046\nG1 X192.147 Y108.162 E4.93406\nG1 X192.1 Y107.743 E.01243\nG1 X24.779 Y107.743 E4.93144\nG1 X24.833 Y107.324 E.01245\nM73 P3 R1204\nG1 X191.936 Y107.324 E4.92505\nG1 X191.699 Y106.905 E.0142\nG1 X24.889 Y106.905 E4.91638\nG1 X24.959 Y106.486 E.01252\nG1 X191.401 Y106.486 E4.90555\nG1 X191.332 Y106.394 E.0034\nG1 X191.321 Y106.067 E.00964\nG1 X25.046 Y106.067 E4.90062\nG1 X25.056 Y106.012 E.00166\nG1 X25.061 Y105.987 E.00074\nG1 X25.119 Y105.714 E.00823\nG1 X25.126 Y105.648 E.00195\nG1 X191.306 Y105.648 E4.89785\nG1 X191.304 Y105.59 E.0017\nM73 P3 R1203\nG1 X191.295 Y105.499 E.00272\nG1 X191.251 Y105.229 E.00805\nG1 X25.163 Y105.229 E4.89512\nG1 X25.17 Y105.15 E.00235\nG1 X25.171 Y104.944 E.00607\nG1 X25.174 Y104.894 E.00146\nG1 X25.18 Y104.81 E.00248\n'
  H:\3d_cheap_piece_of_crap\klipper_hcet14\forum\klipper-internal-error-on-command-g1\klippy_logs\1\klippy (1).log (1 hit)
	Line 5332: Virtual sdcard (141491): 'E.00524\nG1 X104.709 Y192.7 E.00076\nG1 X190.031 Y107.378 E4.46501\nG1 X189.675 Y107.109 E.01649\nG1 X189.684 Y107.02 E.00332\nG1 X189.685 Y106.988 E.00116\nG1 X103.977 Y192.697 E4.48523\nG1 X103.809 Y192.694 E.00623\nG1 X103.398 Y192.677 E.01521\nG1 X103.302 Y192.666 E.00358\nG1 X103.273 Y192.666 E.00108\nG1 X189.715 Y106.223 E4.52363\nG1 X189.697 Y105.702 E.0193\nG1 X189.669 Y105.534 E.00632\nG1 X102.587 Y192.616 E4.55714\nG1 X102.504 Y192.607 E.00306\nG1 X102.072 Y192.568 E.01607\nG1 X101.909 Y192.559 E.00604\nG1 X189.498 Y104.97 E4.58365\nG1 X189.47 Y104.895 E.00293\nG1 X189.426 Y104.726 E.00649\nG1 X189.409 Y104.685 E.00162\nG1 X189.91 Y103.823 F9000\nG1 F4800\nG1 X101.27 Y192.462 E4.63861\nG1 X101.258 Y192.461 E.00047\nG1 X100.731 Y192.349 E.01992\nG1 X100.656 Y192.341 E.00278\nG1 X190.044 Y102.953 E4.67775\nG1 X189.926 Y102.421 E.02018\nG1 X189.895 Y102.367 E.00231\nG1 X99.995 Y192.267 E4.7046\nG1 X99.436 Y192.213 E.02078\nG1 X99.317 Y192.21 E.0044\nG1 X189.636 Y101.89 E4.72653\nG1 X189.586 Y101.802 E.00374\nG1 X189.312 Y101.479 E.01569\n'
I have a suspicion, but nobody will like it.
Update on my trouble shooting is as below.
What I have already checked.
  1. Changed USB Cable.
  2. Removed Web Camera.
  3. Changed 10Amp. SMPS.
  4. Changed Raspberry PI Power Supply.(official raspberry pi 5 adaptor & 3 Amp. adaptor)
  5. Re-Flashed Raspberry pi with latest klipper image.
  6. Changed SD Card of Raspberry pi with latest Klipper image.
  7. Generate test G-code which moves only X and Y axis. (Nozzle and bed heating off)
    X_Y.gcode (16.2 KB)
  8. Changed Slicing Software. (Orca and Prusa slicer 2.9.0)
  9. Open MCU box and tightened all cables and connectors.
  10. check connector of all steeper motor for any loose connection.
  11. Check X and Y axis movement for any binding.
After above steps I faced similar problem randomly. i.e. three long print (12+ hours) tried without filament inserting which completed without any problem. but once in while machine showing MCU disconnection error.
Recently i have changed Raspberry PI on which klipper is running. and used spare Raspberry PI2W.
machine is running ok with my test G-code so I have started printing with filament. print time is around 11 hours.
What is to be checked/changed so far
  1. Change MCU Board.
  2. Check all cables form MCU to each devices for any insulation damage or shorting with ground.
A few questions back:
  1. When the test fails randomly - where is the toolhead? I’m still thinking about your posts above where the toolhead was at the right side of the printer. Is this still the case?
  2. What OS are you running on the Raspberry Pi? What do you installed other than Klipper?
  3. What is the “PI2W”? What is the OS and what apps do you have installed on it?
Every time fault occured tool head position is at far end from x home posion. arround 190 to 198 mm.
OS detail on PI4
Operating System: Debian GNU/Linux 11 (bullseye)
Kernel: Linux 6.1.21-v8+
Only Klipper is running on PI4.
Architecture: arm64
“PI2W”? is Raspberry Pi Zero 2 W board.
OS Detail
 Architecture: arm64
Only Klipper is running on it.
Thank you for the information.
To use a Shanin term, this appears to be a “Red X”. What happens if you run a print (with the rPi 4B) that doesn’t go past 180mm?
Let’s see if you can do prints without errors on smaller models that don’t go across the printer.
I’ve been following this thread and I just did a quick scan and there are some things I’m not sure of. Please bare with me for a few questions so I can be level set on things. I know they may be answered above but there’s a lot to go through.
What kind of analysis has been done on the main controller board (the “AVR Atmega1284P”)? Is this the board that came with the printer?
You said that you’ve been running reliably for a year before these problems started. What was the firmware you were running and did you connect your “AVR Atmega1284P” to any kind of host?
I just looked at the latest klippy.log from the “New SD Log.zip” you posted. There are quite a few “TIMELAPSE” macros in you printer.cfg - what are they and what happens when you run without them?
I can’t remember what are the default mainsail.cfg macros - are you running them or are your PAUSE, CANCEL different? If they are different, what happens if you run the default mainsail.cfg macros?
The question I was really asking was what other apps do you have installed on your rPi 4B other than Klipper. Is there anything of note?
I think you installed Klipper using KIAUH - is this correct or did you use the MainsailOS available to the rPi?
Same questions as with the rPi 4B - any other applications running on it and how did you install Klipper?
Can you confirm that you can run the same gcode files that are failing on the rPi 4B with the rPi Zero 2W without failing? You’re implying that but I want to make sure I’m reading this correctly.
Final question, what is the printer.cfg running on the rPi Zero 2W? Is there any difference between that and the rPi 4B?
So, it seems there are two pieces of very significant information here. The first is that the errors occur when the toolhead is at an extreme position and the other is that you can run without issue using the rPi Zero 2W as your host.
Unless there’s something I’m missing, then I would suggest that you focus your efforts around these two facts.
