Printer Model: Ender 3 V2
MCU / Printerboard: Bigtreetech SKR 3 EZ
Hey everyone,
when I am printing PLA with 220°C/45°C all works fine the prints run without any issues. But when I try to print ABS at 260°C/100°C it fails after about 10-15min with the message that the klipper lost the communication with the mcu. But that is all. I could get any solution from the logs. The thing is, another printer (Flsun SuperRacer) works without any issue at that temps.
Before printing I tuned the PIDs for the said temperatures. Can someone help me?
Greetings
DerKnerd
klippy.log (3.9 MB)
This gets written to the journalctl, the thing is though, it doesn’t matter which cable I use. I used the cable of the SuperRacer to check if it is a cable issue. I even swapped the mainboard with a different one, same model though.
Jan 29 05:40:06 printer-server kernel: usb 1-1.2.2: USB disconnect, device number 13
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: new full-speed USB device number 14 using ehci-pci
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: Product: stm32h743xx
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: Manufacturer: Klipper
Jan 29 05:40:09 printer-server kernel: usb 1-1.2.2: SerialNumber: 410030000751303137353839
Jan 29 05:40:09 printer-server kernel: cdc_acm 1-1.2.2:1.0: ttyACM1: USB ACM device
Jan 29 05:40:09 printer-server snapd[802]: hotplug.go:200: hotplug device add event ignored, enable experimental.hotplug
This could an issue with your power supply. The voltage might be dipping under the sustained load of running the bed at 100C.
I suspected it might be an issue with the power supply. I will try a lower bed temp.
It was the power supply, after lowering the bed temps it worked fine.
