Greetings! I am running klipper with mainsailos. Recently, I made my rPi a secondary mcu and ran a servo on it. This is a sg90 9g Angular Servo. For some reason, it cannot stop jittering. Any suggestions?
This is my servo declared in printer.cfg.
[servo my_servo]
pin: rpi:gpio17 # 11 pin
# PWM output pin controlling the servo. This parameter must be
# provided.
maximum_servo_angle: 180
# The maximum angle (in degrees) that this servo can be set to. The
# default is 180 degrees.
minimum_pulse_width: 0.0005
# The minimum pulse width time (in seconds). This should correspond
# with an angle of 0 degrees. The default is 0.001 seconds.
maximum_pulse_width: 0.0024
# The maximum pulse width time (in seconds). This should correspond
# with an angle of maximum_servo_angle. The default is 0.002
# seconds.
initial_angle:0
# Initial angle (in degrees) to set the servo to. The default is to
# not send any signal at startup.
