Printer Model: LDO Trident 300mm Cube
MCU / Printerboard: LDO Nitehawk
Host / SBC ???
klippy.log: https://drive.google.com/file/d/15bSBZdjaD_PsUFSAQB2UWujKovGx_uEg/view?usp=sharing
Printer config:
https://drive.google.com/file/d/1KUwJV7yx-ex8n35sl4rXJ51kzwuN3RBb/view?usp=sharing
Hi all,
I have installed and setup my LDO nitehawk for the past 2 weeks and it is has been causing so much fustration with "Lost coummuication with MCU ‘nhk’ "and it got to the point where it will shut down after 5mins of starting a print. I check the cable and connector all seem to be fine and it has lead me to believe it could be in the code. I have attached the klipper and pritner config for you hoping I can find the cause and find a fix for this.
