Klipper with IDEX hot end temperate management
Printer Model: JG MAKER ARTIST D PRO
MCU / Printerboard:MKS ROBIN PRO V1.0
On the Klipper website under Features, it says that Klipper supports IDEX where extruders have shared heaters… This printer independently heats the hotend (for different materials as an example). Am understanding that Klipper won’t be able to manage the hot end heaters independently?
Hello @Whit !
Sure it can heat independently:
So, in this sample file, the primary extruder heater is on heater_pin: ar10 and the secondary extruder is on heater_pin: ar11. Is this correct?
It’s an example.
The actual pins you have to take from your printer board.
Now looking for a klipper configuration for this printer. Any suggestions ?
