Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
Klippy is crashing without any good reason.
Ive changed the BTT PI, ive updated klipper.
It does seem to be connected to the file its printing.
And it also looks like it has something to do with the 2nd layer of the print.
I can not find some sort of unprocessed Gcode or something like this.
Ive had these issues before, but they seemed to have resolved itself.
But back then they were connected to using superslicer.
Prusaslicer did not have these issues, and now I changed to orcaslicer and they are back again.
So im a bit puzzled why this is happening.
Cuz there is an issue on GitHub saying klipper can not process the G1 command without an axis.
But the slicer keeps putting multiple of these lines in.
Stats 1036.1: gcodein=0 mcu: mcu_awake=0.013 mcu_task_avg=0.000024 mcu_task_stddev=0.000019 bytes_write=56150 bytes_read=52511 bytes_retransmit=9 bytes_invalid=0 send_seq=2537 receive_seq=2537 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=53 upcoming_bytes=0 freq=83996262 can0: mcu_awake=0.016 mcu_task_avg=0.000017 mcu_task_stddev=0.000020 bytes_write=16395 bytes_read=31299 bytes_retransmit=2029 bytes_invalid=0 send_seq=851 receive_seq=851 retransmit_seq=851 srtt=0.003 rttvar=0.002 rto=0.025 ready_bytes=31 upcoming_bytes=0 freq=64000210 adj=64003225 sd_pos=45225 ToolheadPCB: temp=31.5 heater_bed: target=105 temp=104.7 pwm=0.953 print_time=201.226 buffer_time=2.202 print_stall=0 extruder: target=260 temp=241.6 pwm=1.000 sysload=0.34 cputime=12.719 memavail=676196
b'Got error -1 in can write: (105)No buffer space available'
Stats 1037.1: gcodein=0 mcu: mcu_awake=0.013 mcu_task_avg=0.000024 mcu_task_stddev=0.000019 bytes_write=58108 bytes_read=52871 bytes_retransmit=9 bytes_invalid=0 send_seq=2575 receive_seq=2575 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=7 upcoming_bytes=0 freq=83996265 can0: mcu_awake=0.016 mcu_task_avg=0.000017 mcu_task_stddev=0.000020 bytes_write=17122 bytes_read=31515 bytes_retransmit=2274 bytes_invalid=0 send_seq=866 receive_seq=866 retransmit_seq=866 srtt=0.002 rttvar=0.002 rto=0.025 ready_bytes=56 upcoming_bytes=0 freq=64000205 adj=64003176 sd_pos=47904 ToolheadPCB: temp=31.5 heater_bed: target=105 temp=104.8 pwm=0.570 print_time=202.353 buffer_time=2.328 print_stall=0 extruder: target=260 temp=241.9 pwm=1.000 sysload=0.34 cputime=12.768 memavail=676196
Stats 1038.1: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000024 mcu_task_stddev=0.000019 bytes_write=60252 bytes_read=53271 bytes_retransmit=9 bytes_invalid=0 send_seq=2615 receive_seq=2615 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=33 upcoming_bytes=0 freq=83996262 can0: mcu_awake=0.016 mcu_task_avg=0.000017 mcu_task_stddev=0.000020 bytes_write=17985 bytes_read=31760 bytes_retransmit=2518 bytes_invalid=0 send_seq=882 receive_seq=882 retransmit_seq=877 srtt=0.002 rttvar=0.001 rto=0.025 ready_bytes=40 upcoming_bytes=0 freq=64000205 adj=64003033 sd_pos=49483 ToolheadPCB: temp=31.8 heater_bed: target=105 temp=104.9 pwm=0.812 print_time=203.417 buffer_time=2.391 print_stall=0 extruder: target=260 temp=241.9 pwm=1.000 sysload=0.34 cputime=12.817 memavail=676312
Stats 1039.1: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000024 mcu_task_stddev=0.000019 bytes_write=62778 bytes_read=53676 bytes_retransmit=9 bytes_invalid=0 send_seq=2662 receive_seq=2662 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=9 upcoming_bytes=0 freq=83996265 can0: mcu_awake=0.016 mcu_task_avg=0.000017 mcu_task_stddev=0.000020 bytes_write=19007 bytes_read=31989 bytes_retransmit=2827 bytes_invalid=0 send_seq=900 receive_seq=900 retransmit_seq=900 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=39 upcoming_bytes=0 freq=64000209 adj=64003070 sd_pos=50736 ToolheadPCB: temp=31.8 heater_bed: target=105 temp=105.0 pwm=0.592 print_time=204.035 buffer_time=2.009 print_stall=0 extruder: target=260 temp=243.1 pwm=1.000 sysload=0.34 cputime=12.903 memavail=676312
Transition to shutdown state: Heater extruder not heating at expected rate
See the 'verify_heater' section in docs/Config_Reference.md
Even if there is some communication issue with CAN0 device,
There is a heater issue, it is not normal to have a +0.3-degrees increase per 3 seconds with 100% PWM on the hotend.
So, there is either a heater issue or a thermistor.
