Help with artillery x1 with klipper
Since I installed Klipper this week I can’t print.
Can you send me the printer.cfg file?
I used this ‘Clanks-Klipper-Configs/SideWinder X1 Stock.cfg’, but it doesn’t print. I can move the axes, heat the bed and extruder, I calibrated everything, even the slicer with Klipper.
It worked fine in Marlin. Thanks!
Sorry for the English, I used a translator.
Hello @miladepollio !
With the information that have been asked in the template you have deleted, it may be a bit more easy.
Please attach the klippy.log to your next post.
klippy(3).log (131.1 KB)
Now it’s printing, it’s the 4th time I’ve installed everything, magically.
Thanks, I’ll let you know if there’s any error.
Yes, after 7 days without printing (printing something and then not printing anymore), after installing and uninstalling Klipper many times I found the error.
The machine gcode start of the slicer has some conflict with Klipper, since if I delete the gcode from the slicer, I can print manually (I have to set the temperature first and hit start)
Any idea what I could do to make it automatic? Thanks
klippy(10).log (1.2 MB)
moonraker(7).log (49.7 KB)
