Klipper working printer.cfg file for sidewinder x1 witn mks gen L board
New to this discord and klipper. I have a working printer.cfg file for stepper x,y,z, extruder, hotend, nozzle and parts cooling fan. Also extruder heats up and bed heats up, no problem. Pinouts worked with ramps board cfg. Without reinventing the wheel, is there code to paste in to my printer.cfg for bltouch, mesh_mesh, bed_screws, my extruder fan and any other codes I might need. The codes for ramps board is the only thing i could get working. I can provide a copy of my working printer.cfg file if needed.
Welcome Brian.wendel6,
always use the template.
You might use the search function.
Not necessary if you fill out the template and attach a klippy.log. Everything is in there and we’ll know your hardware from the template.
Sorry, where is the template and how do i attach klipper log?
Thank you for your help
Sorry, Can’t find a template to complete. attached is klippy.log
(attachments)
klippy.log (29.9 KB)
@Brian.wendel6 !
Why have you deleted this and did not take care for it?
[DELETE_ME_AFTER_READING]
This category is for posting working configs only. It is not intended for support or questions.
[/DELETE_ME_AFTER_READING]
Please attach these requested informations to your next post:
Printer Model:
MCU / Printerboard:
BTW: I moved the thread to the correct sub-forum
