I have an alfawise u20 or longer lk1 and I would like to switch it to klipper but I can’t find the printer.cfg file for my printer.
premise I’m a novice
Hello @pietro !
This is an English language based forum.
Please write in English - you may use the help of online translators.
Welcome pietro,
There is a printer.cfg listed.
Good luck, hcet14
But I have the lk1 without bltouch in theory the above mentioned file has the bltouch ba ok the same or do I have to make changes if I have to make changes what do I have to do. Thanks for any help
You cane leave the [bltouch] section away and have to make a change in this section:
step_pin: PE0
dir_pin: !PB9
enable_pin: !PE1
rotation_distance: 8
endstop_pin: probe:z_virtual_endstop # <----------
position_max: 400
For the endstop_pin you have to find the proper pin#. !PE6 should work.
endstop_pin: PE6
or
endstop_pin: !PE6
You have to check.
[bltouch]
sensor_pin: PE6 # Z-Min pin (White Wire)
control_pin: !PD13 # Servo control pin (Orange wire)
z_offset: 2
#stow_on_each_sample: False
#probe_with_touch_mode: False
