Longer lk1 (alfawise 20) Klipper Setup & Configuration Issues
Hello sir,
I don’t think I explained my point clearly enough:
  1. I followed the link you provided and even contacted the person who posted it for support.
  2. For my wiring, orange on 13 and white on 6, plus the 3D Touch was working perfectly on the Marlin firmware, so the possibility of a defective BL Touch or bad wiring is unlikely.
  3. As I mentioned, when I supply the machine with current, the BL Touch goes out and in twice by itself. On Marlin, this indicates that the BL Touch is functioning correctly.
  4. For the config file, I tried several combinations, but as you see, I didn’t get any results.
last log file
klippy (5).log (871.0 KB)
my cfg file
printer (5).cfg (2.2 KB)
