Friends. I want to run the light control macro. “on” and “off” buttons work. I can’t run “light toggle”. This may not be an obstacle in terms of usage. But I want to add a physical button to my printer and turn the lights on and off with a single button. I couldn’t find where I made a mistake. I need your help.
light_control.txt (1.4 KB)
For you was greeted with this text when you opened this thread:
[DELETE_ME_AFTER_READING]
This category is for posting working macros only. It is not intended for support or questions.
[/DELETE_ME_AFTER_READING]
I’ll move your thread.
I am really sad. I couldn’t understand it because it’s not my native language. Thank you.
The only thing I can think of to try would be something like this:
[gcode_macro lights_off]
SET_PIN PIN=caselight VALUE=0|int
[gcode_macro lights_on]
SET_PIN PIN=caselight VALUE=20|int
[gcode_macro lights_toggle]
{% if (printer["output_pin caselight"].value)|int == 20 %}
lights_off
{% else %}
lights_on
theophile thanks.
I somehow got it working today by chance. everything is okay right now. I will definitely try the arrangement you wrote. Thank you again for your help.
