Loading default heightmap on startup?
Hi
is it possible to auto - load a heigtmap on startup?
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	  -0.232500, -0.305000, -0.332500, -0.297500
#*# 	  -0.327500, -0.330000, -0.401250, -0.437500
#*# 	  -0.363750, -0.347500, -0.400000, -0.430000
#*# 	  -0.246250, -0.292500, -0.233750, -0.281250
#*# tension = 0.2
#*# min_x = -5.0
#*# algo = lagrange
#*# y_count = 4
#*# mesh_y_pps = 2
#*# min_y = -10.0
#*# x_count = 4
#*# max_y = 329.99
#*# mesh_x_pps = 2
#*# max_x = 430.0
Add BED_MESH_PROFILE LOAD=default to your start-gcode
under:
serial = /dev/ttyAMA0
restart_method: command
g-code, you mean in Cura?
