I’m not sure since when, but I think it’s been since the last klipper update, which I did about a week ago.
Well, I take the bed_mesh out of the bed, when it’s done, it takes out the report… while I don’t turn off the printer, the bed_mesh can be consulted through the mainsail web interface… but when I restart/turn off… the map of height is NOT loaded
If this block of text appears to me, at the end of printer.cfg… it looks like a list of the bed_mesh… but I am not sure that it is applying it when I print… of course in the web interface, it does NOT appear loaded
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.147707, 0.035730, 0.028386, 0.081824, 0.178230, 0.094168, 0.063855
#*# -0.188332, -0.018957, 0.003386, 0.084480, 0.104324, 0.031511, -0.030364
#*# -0.211145, -0.075051, -0.069895, 0.001199, 0.034480, -0.045676, -0.143957
#*# -0.302707, -0.167551, -0.169895, -0.113801, -0.051770, -0.128176, -0.157082
#*# -0.334739, -0.141770, -0.211926, -0.477082, -0.487082, -0.580364, -0.674739
#*# -0.827082, -0.733020, -0.709426, -0.663957, -0.670051, -0.779114, -0.819582
#*# -0.939270, -0.810364, -0.868489, -0.829895, -0.858489, -0.980051, -1.094114
#*# tension = 0.2
#*# min_x = 20.0
#*# algo = bicubic
#*# y_count = 7
#*# mesh_y_pps = 2
#*# min_y = 20.0
#*# x_count = 7
#*# max_y = 359.96
#*# mesh_x_pps = 2
#*# max_x = 365.0
#*# [bed_mesh Malla10x10]
#*# version = 1
#*# points =
#*# -0.207200, -0.028138, 0.012643, -0.010638, 0.008581, 0.087643, 0.166706, 0.100768, 0.016862, -0.016575
#*# -0.147200, -0.034857, -0.012357, -0.018450, 0.029206, 0.071081, 0.110612, 0.079518, 0.012956, 0.013112
#*# -0.157357, -0.070638, -0.027982, -0.006263, 0.031237, 0.050612, 0.111237, 0.093268, 0.032956, -0.040638
#*# -0.240169, -0.142982, -0.104544, -0.107513, -0.081575, -0.038450, 0.014050, -0.024388, -0.095169, -0.121575
#*# -0.275169, -0.195950, -0.142044, -0.154075, -0.165482, -0.081732, -0.043607, -0.106888, -0.175638, -0.199700
#*# -0.377982, -0.287044, -0.251419, -0.257513, -0.217669, -0.183294, -0.152357, -0.198294, -0.243294, -0.246888
#*# -0.377357, -0.294700, -0.264544, -0.260325, -0.255482, -0.239232, -0.243138, -0.324388, -0.388294, -0.437669
#*# -0.923138, -0.820169, -0.785638, -0.794075, -0.768607, -0.370325, -0.380325, -0.426888, -0.491575, -0.520169
#*# -0.969700, -0.892044, -0.907513, -0.905013, -0.924857, -0.944232, -0.944857, -1.046575, -1.123607, -1.151419
#*# -1.206732, -1.078138, -1.127825, -1.159700, -1.157200, -1.147669, -1.140169, -1.233138, -1.285794, -1.338607
#*# tension = 0.35
#*# min_x = 20.0
#*# algo = bicubic
#*# y_count = 10
#*# mesh_y_pps = 2
#*# min_y = 20.0
#*# x_count = 10
#*# max_y = 359.93
#*# mesh_x_pps = 2
#*# max_x = 364.97
