Lost communication with MCU 'btt_lis2dw
Printer Model: Custom Build
MCU / Printerboard: BTT Manta e3ez
Host / SBC BTT CB2
Describe your issue:Hello,
Has anyone experienced this error? “Lost communication with MCU 'btt_lis2dw”. I installed the accelerometer a few months ago and it’s been functioning fine. Now I can’t get through homing without the Klipper crashing and getting this message. I’ve tried to comment it out in printer.cfg but it still fails. If no one has a solution for this then I am fine with removing it from the system, but I have no idea how to do that. Any kind of help would be greatly appreciated. Attached is my Klippy.log. It looks like the error occurs the first time today on line-4055.
klippy.log (1.3 MB)
This is often indicative to wiring issues or other hardware defects. For a general explanation see Timeout with MCU / Lost communication with MCU
Thank you for the response. I just added some leds to the system. Maybe by adding them I maxed out my power supply. I will run through the options in the link you included.
Is there a way to disable the accelerometer in the meantime so I can use the printer without it shutting down?
Thank you
