I am working on the integration of my 3D Printer (Mainsailos, Moonraker, Klipper) into my home automation with MQTT (Node-Red). I like to send MQTT messages from GCODE and trigger from there actions in Node-Red.
My current working solution is to listen to M117 (display_text). I would prefer to use GCODE M118, but didn’t find a way to get it published to MQTT. Or to use a gcode for publishing MQTT messages. Anybody has solved this or a similar problem?
TIA Markus
it is as simple as this:
add this anywhere to one of your *.cfg
[gcode_macro PUBLISH_ALERT]
{% set data = params.PAYLOAD|default(None) %}
{action_call_remote_method("publish_mqtt_topic",
topic="klipper/gcode",
payload=data,
qos=0,
retain=False,
use_prefix=True)}
Then you can use this here to publish a message to your node-red, just change MESSAGEyouWANThere => what I didn’t found out, how to send a variable with this
PUBLISH_ALERT PAYLOAD=MESSAGEyouWANThere
Nice, it might be worthwhile to mention that this needs a Moonraker setup with properly configured MQTT host. Ref Configuration - Moonraker
I thought that would be clear, as @FotoFieber already told us that he is able to get the display_text working ![]()
but maybe someone can tell me how to publish not just a message with a variable with the PUBLISH_ALERT thing
Something like this?
[gcode_macro MYMESSAGE]
variable_my_msg: None
SET_GCODE_VARIABLE MACRO=MYMESSAGE VARIABLE=my_msg VALUE="'Hello World'"
send_my_message
[gcode_macro MYMESSAGE2]
SET_GCODE_VARIABLE MACRO=MYMESSAGE VARIABLE=my_msg VALUE={printer.heater_bed.temperature}
send_my_message
[gcode_macro send_my_message]
{% set temp = printer['gcode_macro MYMESSAGE'].my_msg | string %}
PUBLISH_ALERT PAYLOAD="{temp}"
Beware:
- I’m not a Klipper macro wizard
- Most likely there is a more elegant / more “correct” way
works like a charm
vote @Sineos for Klipper macro wizard ![]()
EDIT: mhhhh this seems not to work, could you help me out once more?
[gcode_macro M117]
rename_existing: M117.1
M117.1 { rawparams }
M118 { rawparams }
{% if printer["gcode_macro RatOS"].mqtt_alerts|lower == 'true' %}
SET_GCODE_VARIABLE MACRO=MYMESSAGE VARIABLE=my_msg VALUE={ rawparams }
send_my_message
This leads to this error here:
See, we already reached the end of my macro wizardry
apart from this, the title is already taken by @mental
To be honest I have no clue. “Traditional style” Gcode commands like M117 are parsed differently to Klipper’s “extended style” macros. The rawparams are kind of a special construct, so I’m not sure if or how this is going to work.
