Hi developers,
I am trying to understand how Moonraker submits GCode to Klipper and how that GCode is being executed.
From what I know, Klipper does not have a GCode queue. It just uses a mutex to lock the GCode object and execute the entire “script”, which could be a single GCode command or an entire macro.
However, it seems that if the printer is running my PRINT_START macro and I submit a command through the Mainsail interface, that command does not wait for the end of the entire PRINT_START macro.
So, it seems that there is some interleaving of commands. I’d like to understand how that is done.
Thank you.
