I Can't open gcode file
Hi, I just installed mainsail on rpi 4B via Raspberry pi Imager, boot it and upgrade klipper, moonraker to the latest version. Then I flash a board on my printer sidewinder x2. Mainsail connect with the printer, I can home, heat nozzle and bed, send gcodes via terminal, but when I wont open gcode file I get error: unable to open file. I read many topics in the internet about this problem. Firstly I have a warning from moonraker that [virtual_sdcard] is wrong. I changed it to:
[virtual_sdcard]
path: ~/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
Then warning disapear, but problem not. I am still not able to open file. I can import it via mainsail. I check via WinSCP that file is in correct folder home/pi/printer_data/gcodes.
Mayby someone has same problem and could help me to resolve this.
Marcin
Post your klippy.log like you were instructed when you created this post.
