Otherwise, it seems that the main MCU is connected by USB: RESERVE_PINS_USB=PA11,PA12
and, as far as I understand, CB1 is installed on the Manta board.
So, I’m not sure what can cause such connection issues.
Regards,
-Timofey
Also, side note: it is not related to the issue, but it is weird that you have an older Klipper host than the MCU firmware:
That’s the thing – I have no idea what’s causing it either.
As for the firmware – I’ve also swapped the SD card for the CB1 and tried different images, but the same error keeps appearing. I’m starting to wonder if I’m missing something in the Klipper config.
Doubt so, it is either a low-level software issue (kernel) or a hardware issue.
There are no magic config settings that affect this.
So, I guess the only actionable thing you can do is try using UART or something. Basically, attempt to ditch USB, as it seems to have issues in your setup.
If you have a camera attached, or any other usb device, remove it and see if that changes anything.
The usb hub chip built into the manta board that splits between the mcu and the onboard usb socket it not the best and i have seen it cause this issue before.
I got rid of all TTC by just upgrading from CB1 to CM4… it was ok 2 years ago when I bought it, but lately it errored out doing imput shaper(trough Klipper Shake&Tune plugin ).
Super long shot…
Check your Moonraker log for unusual activity. I had a seemingly random TTC issue on one of my machines. Turns out I had a leftover service from an uninstalled package (HelixScreen) that would flood Moonraker with connection attempts.
