The errors you are seeing are created by the MAX81855 chip and point to a hardware / wiring issue.
Note that the MAX81855 is very sensitive to external influences. E.g. it cannot handle grounded probes. This means when your temperature sensor touches some metal and gets a ground potential (or any other voltage potential) the chip will go into an error state
