MCU connect issue
daVinci AiO
MCU / Printerboard:BTT SKR Mini E3 V3.0
klippy.log (68.9 KB)
A daVinci AiO landed on my bench with a ‘Bricked’ control board. With davinci10’s help tried to revive - no joy. I have rewired and fitted a BTT Mini E3 and a R Pi 2 to Kliperize it. As per BTTs ’ direction in the config header I created the firmware.bin file and the printer.cfg file. This was installed and confirmed as the board renamed the file to 'FIRMWARE.CUR* as expected.
I have checked everything I can think of but stil cannot connect to the MCU. I get this message:
“mcu ‘mcu’: Unable to connect
Error configuring printer”
The R Pi has this as a lsusb report:
“bill@davinci2:~/klipper $ lsusb
Bus 001 Device 005: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 006: ID 1d50:614e OpenMoko, Inc. stm32g0b1xx
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub”
The detail of Device 006: 1d50:614e and stm32g0b1 was in the menuconfig part of ‘make’.
Any suggestions as to what to try next ?
You may try the suggested command in Frequently Asked Questions - Klipper documentation.
“Where’s my serial port?”
Good luck, hcet14
Solved ! The serial address in the generic BTT file and the real address differed:
serial: usb-Klipper_stm32g0b1xx_12345-if00
and
serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_12345-if00
Now on to the other issues !
