MCU 'mcu' shutdown: Move queue overflow. Sovol SV08
Printer Model: Sovol SV08
MCU / Printerboard: stm32f103xe
Host / SBC aarch64, 64bi
klippy.zip (3.3 MB)
I’ve had this SV08 for just over a month, however I have been having intermittent issues with the MCU Overflow error mid print. The problem does not allow me to use fuzzy skin, or exclude object - guaranteed fail.
The problem however is now getting much more common, and it’s probably 50% failure rate now no matter my slicer settings.
I’m printing mainly with 0.6mm nozzle, 0.2mm layer height, 200mm/s, 4,000mm/s^2 / 600mm/s, 20,000mm/s^2 travel.
From the klipper logs I can see the buffer is emptying before failure, but I’m not sure why the problem seems to be getting worse?
Hello @Magnetonastick !
Git version: 'v0.12.0-0-g02eeceb-dirty'
Modified files: klippy/__pycache__/msgproto.cpython-310.pyc, klippy/__pycache__/msgproto.cpython-38.pyc, klippy/chelper/__init__.py, klippy/chelper/compiler.h, klippy/chelper/itersolve.c, klippy/chelper/itersolve.h, klippy/chelper/kin_cartesian.c, klippy/chelper/kin_corexy.c, klippy/chelper/kin_corexz.c, klippy/chelper/kin_delta.c, (+187 files)
Have you already tried with a clean and recent version of Klipper? The "dirty" Flag and the Team's Position, Releases - Klipper documentation
