MCU 'mcu' shutdown: Timer too close error ONLY when using OrcaSlicer
Printer Model: Voron 2.4
MCU / Printerboard: Spider V2.3
Host / SBC: RPI 4B 2GB, EBB36 V1.2 (both via USB)
bug.zip (2.1 MB)
I’m consistently getting this error every single print since yesterday, over 600hr of print time and suddenly every print fails at layer between 5~10.
I’ve tried reinstall everything, wipe out whole SD card and start over, but nothing changed untill I try switching to PrusaSlicer and suddently everything works and no error whatsoever.
I then try different presets in OrcaSlicer, even different printer presets but that error still pops out at layer 8.
I havn’t change anything in OrcaSlicer before this incident beside some built in calibration tests, so I’m not so sure if this is a slicer problem or a klipper problem.
I’ve include both (good) and (bad) gcode that are from Prusa and Orca respectively, and the log file.
Hello @5jvm0u4 !
OrcaSlicer can produce some weird stuff in connection with the M106 command. Like this from the Bad file:
; stop printing object Voron_Design_Cube_v7 id:0 copy 0
M106 S76
M106 S76
M106 S76
M106 S76
M106 S76
M106 S76
M106 S76
M106 S76
;LAYER_CHANGE
You may update Klipper.
https://www.klipper3d.org/Config_Changes.html
My klipper version is
Version: v0.12.0-321-g8e1cdb199
I believe it’s the lastest version since I just re-install everything today and flashed everything up-to-date.
I’ll try deleting those duplicated M106 and run the modified gcode to see if it helps, I’ll also submit a issue in OrcaSlicer’s GitHub page.
Hope this is the solution, it’s dirving me crazy…
Great appreciation!
I’m not sure what the root cause is, but your host system is under heavy load.
It could be a large number of redundant commands from the slicer. Or it could be traditional host issues (like failing sdcard, overheating, background processes, etc.): Timer too close
After some test, I can confirm this is NOT the cause of this problem, I’m stuck again…
I tune down slicing resolution from 0.005 to 0.05, and now instead timer too close, it emit “Heater extruder not heating at expected rate”, but when I look into log file, it shows that it’s the same problem:
Receive: 99 89994.387698 89994.387310 12: seq: 1c, shutdown clock=3419833690 static_string_id=Timer too close
Transition to shutdown state: Heater extruder not heating at expected rate
bug2.zip (1.3 MB)
It’s G2/G3 that’s causing this problem, OrcaSlicer will still generate, specifically, G3 even when arc fitting is disable, while in PrusaSlicer, it’s actually off when set to off.
That’s why I couldn’t find out why.
I simply change[gcode_arcs]resolution from 0.001 to 0.01 and solve everything.
