MCU not detected after DFU flash (SKIPR v1.0)
Hi everyone, I’m new to this and still learning Klipper setups, so I might be missing something obvious.
Printer Model: Mercury One Zero G
MCU / Printerboard: MKS SKIPR v1.0 (STM32F407)
Host / SBC: Linux (Mainsail + Moonraker)
klippy.log: attached
I am trying to set up an MKS SKIPR v1.0 (STM32F407) with Klipper.
The board enters DFU mode correctly and is detected without issues. Flashing Klipper via dfu-util also completes successfully (“download done / file downloaded successfully”).
However, after rebooting the board, it never enumerates over USB again:
  • no device appears in lsusb
  • no /dev/serial/by-id is created
  • Klipper cannot connect to the MCU
Error in Klipper:
mcu 'mcu': Unable to connect
Error configuring printer
What I already tried:
  • different bootloader offsets (0x08002000)
  • multiple recompiles
  • switching clock between 8 MHz and 12 MHz
  • switching communication interface from USART1 to USB (PA11/PA12)
The behavior stays the same: DFU works and flashing completes successfully, but the board never appears as a USB device after reboot.
There is no klippy.log file.
Please attach it to your next post.
klippy (3).log (117.8 KB)
Are you sure the USB cable is able to transfer data?
Yes, I’m sure. I can access the SKIPR through SSH, and the board is detected correctly in DFU mode. The issue is that after flashing Klipper and rebooting, it no longer enumerates as a USB device.
Are you running the software image from MKS on the embedded host SBC?
I cannot find any information on MCU updates at “official” MKS sites. This does look legit:
It says MCU firmware must ne flashed from SD card.
I find no reference to DFU mode.
I find no reference to the boot & reset switches except they show up in the schematic as wired to the MCU not the SOM (host).
If you have not updated Klipper on the host try flashing the precompiled .bin from MKS:
I use an MKS SKIPR board on my custom-built DIY printer.
Since MKS hasn’t released any firmware updates for the SKIPR since 2020, updating to Klipper v0.13 may result in two warnings related to the MCU and STEPPER_STEP_BOTH_EDGE.
When building the firmware, make sure to select Linux as the micro-controller architecture.
Also, the SKIPR board is flashed through UART, not USB.
If you no longer have access to the board, you can download the SKIPR image from the MKS GitHub repository and install it.
