Printer Model: Artillery Sidewinder X3 Pro
MCU / Printerboard: STM32F402 (compiled as STM32F401), stock Artillery board
Host / SBC: Raspberry Pi 4B, MainsailOS 3.0.0, Klipper v0.13.0-642: attached
klippy.log (277.1 KB)
Converting from stock Marlin to Klipper. Flashed via SD card using the 48KiB bootloader path documented in printer-artillery-sidewinder-x3-plus-2024.cfg. Klipper never connects to the MCU:
mcu 'mcu': Unable to connect
Timeout on connect
Wait for identify_response
The board enumerates over USB reliably and the link stays up, but the identify handshake never completes.
What I’ve verified:
- Flash completed — the bootloader renamed
yuntu.bintoyuntu.CURon the SD card .configshowsCONFIG_STM32_FLASH_START_C000=y(48KiB offset)- Board enumerates consistently as
1d50:614e,Manufacturer: Klipper,Product: stm32f401xc dmesg -wshows zero disconnects during a failed connect attempt- Tried two USB ports on the Pi
fuser /dev/ttyACM0returns nothing — no port contention- Exactly one
klippy.pyprocess running - ModemManager not installed on this image
- With the Klipper service stopped,
console.pyalso fails to identify despite exclusive port access - Tried
restart_method: commandandrestart_method: arduino
Config is F1CU’s X3 Pro adaptation (F1CU/Artillery_Sidewinder_X3_Pro-Klipper) of TheFeralEngineer’s Plus config.
One uncertainty: I can’t confirm which firmware version my unit shipped with — I upgraded it at some point and the UI now reports V1.29. The flashing instructions branch on what the board shipped with (48KiB bootloader vs. no bootloader + DFU). Is there a way to determine which bootloader is actually present on the board, rather than inferring it from firmware history? The yuntu.CUR rename and the fact that the firmware executes both suggest a bootloader is present and the offset is right, but I’d like to confirm rather than assume.
Any suggestions for what else to check would be appreciated.
