Mcu not detecting USB
Printer Model: Ender 3
MCU / Printerboard: SKR Mini E3V3 G Series
klippy.log (300.9 KB)
i have uninstalled and reinstalled klipper, moonraker, mainsail multiple times, and have flashed firmware on ender again just to make sure, even though it connected just fine before. Tried every USB port on debain sonic pad, as well.
Any tips? Thanks!
p.s.
now no matter what I do i cant get the MCU to be found.i also would like to add that when I run sudo systemctl list-units | grep brltty when ssh’d in to the Debian version sonic pad , i get nothing at all to pop up. im not sure why or if thats a even a bad thing but i can not even get kiauh to detect the mcu over usb , but over uart i get ttyS0.
klpper.txt (50.5 KB)
This is the message when running sudo dmesg command from ssh terminal. I’m lost and need help thank you in advance!
We are not supporting the Sonic Pad here. For some explanation refer to Creality Sonic Pad and Alternatives
