Printer Model: Ender 3 NG
MCU / Printerboard: SKR Mini E3 V3
Host / SBC: Pi Zero 2 W
klippy.log (48.3 KB)
I recently swapped out the SD card in my Pi because I was having issues getting my pi to boot. The Pi boots now, but Klipper won’t connect to my MCU. This is a fresh mainsail install onto the new SD. My setup had been working fine previously.
Here are the parts of klippy.log that seem relevant, for ease of access:
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-Klipper_stm32g0b1xx_490009000450415339373620-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-Klipper_stm32g0b1xx_490009000450415339373620-if00'
the above repeats a bunch of times…
MCU error during connect
File "/home/frostbyte/klipper/klippy/mcu.py", line 866, in _attach
self._serial.connect_uart(self._serialport, self._baud, rts)
File "/home/frostbyte/klipper/klippy/serialhdl.py", line 191, in connect_uart
self._error("Unable to connect")
File "/home/frostbyte/klipper/klippy/serialhdl.py", line 68, in _error
serialhdl.error: mcu 'mcu': Unable to connect
File "/home/frostbyte/klipper/klippy/klippy.py", line 131, in _connect
self.send_event("klippy:mcu_identify")
File "/home/frostbyte/klipper/klippy/klippy.py", line 227, in send_event
return [cb(*params) for cb in self.event_handlers.get(event, [])]
File "/home/frostbyte/klipper/klippy/klippy.py", line 227, in <listcomp>
File "/home/frostbyte/klipper/klippy/mcu.py", line 876, in _mcu_identify
self._attach()
File "/home/frostbyte/klipper/klippy/mcu.py", line 871, in _attach
raise error(str(e))
mcu.error: mcu 'mcu': Unable to connect
Error configuring printer
running ls /dev/serial/by-id/* returns the following:
which is also reflected in my printer.cfg:
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_490009000450415339373620-if00
baud: 250000
Later on in the klippy.log, the error repeats with ‘rpi’ instead of ‘mcu’:
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
File "/home/frostbyte/klipper/klippy/mcu.py", line 868, in _attach
self._serial.connect_pipe(self._serialport)
File "/home/frostbyte/klipper/klippy/serialhdl.py", line 173, in connect_pipe
serialhdl.error: mcu 'rpi': Unable to connect
self._attach()
raise error(str(e))
mcu.error: mcu 'rpi': Unable to connect
In mainsail’s devices tab, the mcu does show up. So communications seems to be fine.
Since the mainsail install on my pi is fresh, I have also tried updating the firmware on my mcu. I did not notice any change after that.
Thank you!
