Miscellaneous Fan Slide Bar
Printer Model: Voron 2.4r2
MCU / Printerboard: BigtreeTech STM32F446
Is there a way to have the slide bar for all the fans? I don’t know what enables that in the config file.
I would also like to make sure that the names are accurate, I need to change the name “Fan” to “Print Cooling Fan”
#   Fan Control
##  Print Cooling Fan - FAN0
[fan]
pin: PA8
kick_start_time: 0.5
##  Depending on your fan, you may need to increase this value
##  if your fan will not start. Can change cycle_time (increase)
##  if your fan is not able to slow down effectively
off_below: 0.10
##  Hotend Fan - FAN1
[heater_fan hotend_fan]
pin: PE5
max_power: 1.0
heater: extruder
heater_temp: 50.0
shutdown_speed: 1
##  If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
##  Controller fan - FAN2
[controller_fan controller_fan1]
pin: PD12
max_power: .5
shutdown_speed: 0.0
cycle_time: 0.05
hardware_pwm:true
kick_start_time:0.5
off_below: 0.1
##  Nevermore Filter - FAN3
[heater_fan filter_fan]
pin: PD13
max_power: 1.0
shutdown_speed: 0.0
cycle_time: 0.05
hardware_pwm:true
kick_start_time:0.5
off_below: 0.1
heater: heater_bed
fan_speed: 0.7
##  Controller fan - FAN4
[controller_fan controller_fan2]
pin: PD14
max_power: .5
shutdown_speed: 0.0
cycle_time: 0.05
hardware_pwm:true
kick_start_time:0.5
off_below: 0.1
##  Exhaust fan - FAN5
[heater_fan exhaust_fan]
pin: PD15
max_power: 1.0
shutdown_speed: 0.0
kick_start_time: 5.0
heater: heater_bed
heater_temp: 60
fan_speed: 1.0
You want to read here:
https://www.klipper3d.org/Config_Reference.html#fans
Only the part cooling fan [fan] and [fan_generic my_fan] are manually controlled.
The other fans are controlled by either temperature or active components.
