Must home axis first when starting print
Printer Model: ender 3 v2
MCU / Printerboard: stock ender 3 v2 mainboard (v2.2 i believe)
klippy (1).log (713.7 KB)
I have been trying to get my start macro working, I have everything mostly up and running but keep getting this weird error: Must home axis first: 0.000 0.000 50.000 [0.000]
I believe this issue is caused by trying to preform an auto bed leveling sequence before the printer has been homed. i have tried moving around the home command, homing the x and y axes multiple times but nothing has worked.
start macro:
[gcode_macro START_PRINT]
      # Use absolute coordinates
      G90
      # Reset extruder
      G92 E0
      # Heat the bed and wait
      #50 for pla
      #100 for abs
      M190 S50
      # Home the printer and level bed
      G28
      G28 X Y
      G1 X0 Y0 Z0 F3000
      M84
     # Move to wait position
     G1 X0 Y0 Z50 F4000.0
     # Set and wait for nozzle to reach temperature
     #215 for pla
     #240 for abs
     M109 S215
    # Move Z axis up
    G1 Z2.0 F3000
    # Move to start position
    G1 X10.1 Y20 Z0.28 F5000.0
    # Draw the first line
    G1 X10.1 Y200.0 Z0.28 F1500.0 E15
    # Move to the side
    G1 X10.4 Y200.0 Z0.28 F5000.0
    # Draw the second line
    G1 X10.4 Y20 Z0.28 F1500.0 E30
    # Reset extruder
    G92 E0
Of course: M84 turns the motors off and the homing is gone.
https://www.klipper3d.org/G-Codes.html
Thank you for pointing that out, I somehow came to the conclusion that M84 would level the bed which now that i think about doesn’t make any sense
