Wait a minute: Still 4 weeks left.
Merry Christmas ⌠!
Hello George⌠I installed your macro for the first time today. I tested the macro âNEOPIXEL_DISPLAY LED=âmy_ledâ TYPE=extruder_temp MODE=temp_progressâ. Everything (colors) worked properly in warming up and cooling down. However, after the process is complete, I cannot change the color of the LEDs or turn them off. When I restart the software it goes back to normal. What ending can I apply in this case?
In addition. It would be much more useful if a one-button on/off option like âpwm+toggleâ is added, as in the caselight macro. And also your macros. I canât see it on the macro grouping screen. Whatâs the reason?
Try the beta version where I implemented a Clear function. You could run it on the END_PRINT macro or create a separate macro just with the clear command in order to see it in UI.
thanks a lot. I will give feedback again after trying it.
Great macro! It seems to work like a charm. Question though. How would I go about changing the colors? I donât see how youâre setting the RGB values.
This is cleverly done with the help of display_template
See klipper-neopixel/led_progress.cfg at 53b9d28c8e5d4cea37a104f797310dde9b7042f2 ¡ digitalninja-ro/klipper-neopixel ¡ GitHub
Very nifty, but not immediately obvious.
