Hello,
I went from a octopus pro with 429 chipset to an octopus pro v1.0.1 with a h723 chipset.
My config was transferred without any problem but only for one section.
It seems that SPI3 is not available in the firmware for h723, I get the following error " Unknown spi_bus ‘spi3’ ".
Has this been renamed ? all I can see in the firmware file is a reference to spi3a and spi3 is absent.
this is the portion of my config causing the issue:
[adxl345]
cs_pin: PA15
spi_bus: spi3
Thanks for your guidance.
